node-red-contrib-chroma 0.0.3
color conversion based on chroma.js
npm install node-red-contrib-chroma
A Node-RED node for color conversions This node mostly is based on chroma.js with additional formats like RGBW and CIExyz
chroma.js is a small-ish zero-dependency JavaScript library (13.5kB) for all kinds of color conversions and color scales
features
  • conversion between various color formats
  • conversion between array format (chroma.js default) and objects
  • scaling of relative values either as 0..1 or 0..100
  • support of floating point and integer values
  • chroma.js api accessible to
    • manipulate colors
    • generate color scales
latest updates
0.0.3
  • fix: return callback function
  • updated examples
  • various minor fixes and typos
Either use the Editor - Menu - Manage Palette - Install option, or run the following command in your Node-RED user directory (typically ~/.node-red) after installing Node-RED-dashboard.
npm i node-red-contrib-chroma
Examples
Examples can be imported via import/examples in the top right menu of the editor
  1. conversions test of all (except alpha channel) available formats
  2. mix use of chroma
  3. interactive scale use of chroma scales using the api (with a dashboard slider as input and a button to show the resulting color)
inputs
msg.payload
Alpha channel is supported to most color formats.
For relative values select the format 0..1 or 0..100 to be expected.
chroma.js input formats
  • Hex string: "#ff0000"
  • RGB string: "rgb(255, 0, 0)"
  • RGB object: {r: 255, g: 0, b: 0}
  • HSL string: "hsl(360, 50%, 100%)"
  • HSL object: {h: 360, s: 50, l: 100}
  • HSV object: {h: 360, s: 100, v: 50}
  • HSI object: {h: 360, s: 100, i: 50}
  • LAB object: {l: 1, a: 1, b: 1}
  • LCH object: {l: 1, c: 1, h: 1}
  • named colors: string
  • temperature: number 1000..40,000 k
  • luminance: number 0..1
additional formats
  • RGBW object {r:255, g:255, b:255, w:255} *useful for RGBW LEDs
  • CIExyz object {x:1, y:1, z:1} for home automation like zigbee
Node: CIExy can't be used as input as it can't be converted clearly to RGB (or somebody can to show me how)
msg.api
the api can be accessed by sending an arrayof objects
The first example of the chroma.js api documentation:
chroma.scale(['#fafa6e','#2A4858']).mode('lch').colors(6)
translates to
    { "scale": ["#fafa6e","#2A4858"] },
    { "mode": "lch" },
    { "colors": 6 }
This example will generate a six colors scale form yellow to dark green
If the api call returns a function msg.payload will be used as it's parameter. Subsequent messages (without msg.api) will return the result of the returned callback function
If no msg.payload is sent the callback function is send to the output (to be tested further).
output
All supported input formats can be selected as output. In addition CIExy can be selected
All chroma.js multi value results are formatted as an array. Tick the option to get the result as an object
For relative values select the format 0..1 or 0..100 to be emitted.
Numerical values can be rounded integers or returned as float values
Version: 0.0.3
Updated 5 years, 9 months ago
Rating: 5.0 2
5 in the last week
  • chroma
  • color
  • colour
  • chroma.js
  • chroma
  • conversion
