node-red-contrib-chirpstack-multicast 1.0.0
Node-RED node for ChirpStack v4 multicast downlink
npm install node-red-contrib-chirpstack-multicast
Node-RED node for sending multicast downlinks to ChirpStack v4 LoRaWAN network server. This node was generated using claude.ai
  • ✅ Send multicast downlinks to groups of LoRaWAN devices
  • ✅ Support for ChirpStack v4.x (gRPC API)
  • ✅ Multiple data format support (Buffer, Hex, Base64, UTF-8)
  • ✅ Cayenne LPP compatible
  • ✅ Debug mode for troubleshooting
  • ✅ Complete error handling
Or install directly from Node-RED's palette manager.
Requirements
  • Node-RED >= 2.0.0
  • ChirpStack v4.x
  • LoRaWAN devices in Class C mode
  • Configured multicast group in ChirpStack
1. Add ChirpStack Server Configuration
  1. Drag the chirpstack-multicast node into your flow
  2. Double-click to configure
  3. Create a new server configuration:
    • Server: Your ChirpStack server address (e.g., localhost:8080)
    • API Token: Your ChirpStack API key
2. Configure Multicast Node
  • Name: Optional node name
  • Server: Select your ChirpStack server
  • Group ID: Multicast group ID (optional, can be provided via msg)
  • fPort: LoRaWAN application port (default: 10)
  • Debug: Enable debug logging
Basic Example
msg.multicastGroupId = "4820fc7f-0579-46a6-a67f-96d46e2c0cd7";
msg.fPort = 10;
msg.payload = "Hello World";
Send Buffer
msg.payload = Buffer.from([0x01, 0x02, 0x03, 0x04]);
Send Hex String
msg.payload = "48656C6C6F";  // "Hello" in hex
Cayenne LPP Example
// Temperature sensor (channel 1)
const buf = Buffer.alloc(4);
buf[0] = 1;     // Channel
buf[1] = 0x67;  // Temperature type
buf[2] = 0x01;  // Value high byte (25.6°C)
buf[3] = 0x00;  // Value low byte
msg.multicastGroupId = "your-group-id";
msg.payload = buf;
Complete Weather Station Example
function encodeCayenneLPP(temp1, temp2, hum1, hum2) {
    const buf = Buffer.alloc(14);
    let i = 0;
    // Channel 1 - Temperature
    buf[i++] = 1; buf[i++] = 0x67;
    let t1 = Math.round(temp1 * 10);
    buf[i++] = (t1 >> 8) & 0xFF;
    buf[i++] = t1 & 0xFF;
    // Channel 2 - Temperature
    buf[i++] = 2; buf[i++] = 0x67;
    let t2 = Math.round(temp2 * 10);
    buf[i++] = (t2 >> 8) & 0xFF;
    buf[i++] = t2 & 0xFF;
    // Channel 3 - Humidity
    buf[i++] = 3; buf[i++] = 0x68;
    buf[i++] = Math.round(hum1 * 2);
    // Channel 4 - Humidity
    buf[i++] = 4; buf[i++] = 0x68;
    buf[i++] = Math.round(hum2 * 2);
    return buf;
msg.fPort = 10;
msg.payload = encodeCayenneLPP(25.5, 22.3, 65, 58);
Input
Type: string
Required: Yes (if not configured in node)
The UUID of the multicast group in ChirpStack.
msg.fPort
Type: number
Required: No (default: 10)
LoRaWAN application port (1-223).
msg.payload
Type: Buffer | string | object
Required: Yes
The data to send. Supports:
  • Buffer: Raw binary data
  • Hex string: "48656C6C6F"
  • Base64 string: "SGVsbG8="
  • UTF-8 string: "Hello"
Output
msg.payload (Success)
  "success": true,
  "fCnt": 42,
  "multicastGroupId": "4820fc7f-0579-46a6-a67f-96d46e2c0cd7",
  "fPort": 10,
  "timestamp": "2024-11-05T10:30:00.000Z"
msg.payload (Error)
  "success": false,
  "error": "Error message"
Supported Data Formats
Format Example Detection
Buffer Buffer.from([0x01, 0x02]) Buffer.isBuffer()
Hex "48656C6C6F" Regex: ^[0-9A-Fa-f]+$
Base64 "SGVsbG8=" Regex: ^[A-Za-z0-9+/=]+$
UTF-8 "Hello World" Default fallback
ChirpStack Configuration
Create Multicast Group
  1. In ChirpStack web interface, go to Applications
  2. Select your application
  3. Click Multicast groups → Create
  4. Configure:
    • Name: Your group name
    • Region: EU868, US915, etc.
    • Multicast address: 4-byte address
    • Network session key (McNwkSKey)
    • Application session key (McAppSKey)
    • Frame counter: Start at 0
    • Data rate: Compatible with all devices
    • Frequency: RX2 frequency for your region
Add Devices to Group
  1. Go to your multicast group
  2. Click Add device
  3. Select devices (must be Class C)
Configure Devices for Class C
Your LoRa-E5 modules must be in Class C:
AT+CLASS=C
Troubleshooting
"Multicast Group ID manquant"
  • Ensure multicastGroupId is set in node configuration or msg
"Erreur gRPC"
  • Check ChirpStack server address (default: localhost:8080)
  • Verify API token is valid
  • Check ChirpStack logs: docker logs -f chirpstack
Devices not receiving
  • Verify devices are in Class C mode
  • Check devices are members of the multicast group
  • Verify multicast group frequency and data rate
  • Check ChirpStack gateway connection
Debug Mode
Enable debug mode in node configuration to see:
  • Multicast Group ID
  • fPort
  • Data (hex and base64)
Example Flow
[{"id":"inject1","type":"inject","name":"Test Multicast","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":100,"wires":[["function1"]]},{"id":"function1","type":"function","name":"Prepare Data","func":"msg.multicastGroupId = \"4820fc7f-0579-46a6-a67f-96d46e2c0cd7\";\nmsg.fPort = 10;\nmsg.payload = Buffer.from(\"Hello\");\nreturn msg;","outputs":1,"x":310,"y":100,"wires":[["multicast1"]]},{"id":"multicast1","type":"chirpstack-multicast","name":"Send Multicast","server":"server1","multicastGroupId":"","fPort":10,"debug":true,"x":500,"y":100,"wires":[["debug1"]]},{"id":"debug1","type":"debug","name":"Response","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":680,"y":100,"wires":[]}]
API Reference
gRPC Service
Uses ChirpStack's MulticastGroupService.Enqueue method.
Protobuf Definition
service MulticastGroupService {
  rpc Enqueue(EnqueueMulticastGroupQueueItemRequest) returns (EnqueueMulticastGroupQueueItemResponse);
Contributing
Contributions are welcome! Please:
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Submit a pull request
MIT License - see LICENSE file for details
Author
Votre Nom
Links
Changelog
1.0.0
  • Initial release
  • Support for ChirpStack v4.x
  • Multiple data format support
  • Debug mode
Version: 1.0.0
Updated 1 year, 1 month ago
  • chirpstack-server-multicast
  • chirpstack-multicast
  • chirpstack
  • lorawan
  • multicast
  • lora
  • iot
