node-red-contrib-chartjs 0.5.2
Node-RED Chart.js node
npm install node-red-contrib-chartjs
A Node-RED node to provide charts for plotting things on. Implemented by Chart.js
Charts RED Dashboards
Description
This nodes package permit to use Chart.js charts from Node-RED. The objective is create a new url path for each chart created, this url path could be configured and updated at runtime.
npm install node-red-contrib-chartjs --save
Charts implemented
  • Line Chart
linea_chart
  • Multi Line Chart MultiLinearChart
  • Vertical Bar Chart
vertical_chart
  • Horizontal Bar Chart
horizontal_chart
  • Pie Chart
pie_chart
  • Doughnut Chart
dought_chart
  • Polar Area Chart
polar_chart
  • Bubble Chart
bubble_chart
  • Radar Chart
radar_chart
Chart configuration
The Chart attributes are:
  • Path: The Chart Url to be access. An example where path is TP01 could be:
http://localhost:1880/TP01
  • Tittle: The chart title
  • X Axis: The X axis label
  • Y Axis: The Y axis label
  • Payload: The chart dataset object
The chart payload attributes are:
  • channel: The channel legend
  • color: The chart color line
  • dataset: The chart dataset
The payload dataset attributes are:
  • x: x axis dataset value
  • y: y axis dataset value
Read node help to check the dataset structure for each chart. The Line Charts dataset could be multi serial graphs like this:
[{"channel": "Population",
  "color": "Blue",
  "dataset": [{
      "x": "Europe",
      "y": 741
      "x": "Australia",
      "y": 24
      "x": "Africa",
      "y": 1.2
      "x": "America",
      "y": 325
      "x": "Asia",
      "y": 4.4
  {"channel": "Economy",
    "color": "Green",
    "dataset": [{
        "x": "Europe",
        "y": 12
        "x": "Australia",
        "y": 13
        "x": "Africa",
        "y": 3
        "x": "America",
        "y": 22
        "x": "Asia",
        "y": 18
NOTE: The new multiserial linear chart implementation is compatible with the previous one versions
The rest of the charts dataset are not multiserial graphs. An example could be like this:
    "color": "Green",
    "dataset": [
            "x": "Europe",
            "y": 741
            "x": "Australia",
            "y": 24
            "x": "Africa",
            "y": 1.2
            "x": "America",
            "y": 325
            "x": "Asia",
            "y": 4.4
Dependencies
Server side
Client side
  • socker.io-client: Socket.io client side
  • jquery: Multipurpose javascript library
  • bootstrap4: Build responsive, mobile-first projects on the web
  • popper.js: A kickass library used to manage poppers in the web applications
  • Chart.js: Simple yet flexible JavaScript charting for designers & developers
  • jsPDF: The leading HTML5 client solution for generating PDFs
Example
Under example folder you have a json flow to be imported in your node-red instance to test the nodes.
Version: 0.5.2
Updated 6 years, 4 months ago
License: Apache License, Version 2.0
Rating: 4.0 8
89 in the last week
  • chartjs-line
  • chartjs-vertical-bar
  • chartjs-horizontal-bar
  • chartjs-pie
  • chartjs-doughnut
  • chartjs-polar
  • chartjs-bubble
  • chartjs-radar
  • chart.js
  • chart
  • Andres Carmona
