node-red-contrib-chart-image 1.2.1
Use chartjs to generate charts and output them as image buffers.
npm install node-red-contrib-chart-image
⚠️ Legacy / Deprecated
Version 1.x of this node is deprecated.
Please use v2.0.3 or later.
Migration details are available in the v2.0.3 release notes.
Generate a chart in image form using Chart.js
Details:
A chart image buffer will be generated using the chart.js definition object found in msg.payload. See the chart.js documentation for more info on defining a chart.
Canvas Size:
Setting msg.width and/or msg.height to the desired size in pixels will override the node configuration.
Default Color Pallet:
If no backgroundColor or borderColor is defined for a dataset, Chartjs assigns the global default color of rgba(0,0,0,0.1). To make life a little easier, this node changes that behavior to assign each dataset a color from preset pallet, which includes 32 colors. If you define your own colors in a dataset, that color will be used, you do have to define both backgroundColor and borderColor if both are to be displayed. for line charts, use fill:false to prevent the use of backgroundColor.
Plugins:
This node includes chartjs-plugin-datalabels and chartjs-plugin-annotations. Each can be defined as you would according to their documentation. You can also define the chart background color by defining a chartArea object under the options scope.
chartArea: {
    backgroundColor: 'white'
  • NOTE: chartjs-plugin-datalabels registers itself automatically when imported. This node looks for a display:true object in the datalabels definition to register or unregistert the plugin. This prevents datalabels showing up aninvited.
eg:
msg.payload = {
   options: {
          plugins: {
              datalabels: {
                  display:true
Additional plugins can be used by installing the desired plugin in the Node-RED install directory and following the settings.js example to import the module into your Node-RED instance.
functionGlobalContext: {
        // os:require('os'),
        // jfive:require("johnny-five"),
        // j5board:require("johnny-five").Board({repl:false}),
		myMuchNeededPlugin: require('chartjs-plugin-yourplugin')
From there, you can pass it to your chart vie msg.plugins.
msg.plugins = {
    myMuchNeededPlugin: global.get('myMuchNeededPlugin')
Then you just need to define the plugin options in your chart definition object.
Resources
Please report bugs, suggest improvements!
https://github.com/gemini86/node-red-contrib-chart-image/issues
If you find this node useful,
Buy Me A Coffee
Version: 1.2.1
Updated 11 months, 2 weeks ago
License: BSD-2-Clause
Rating: 5.0 2
139 in the last week
  • chart-image
  • chart
  • chartjs
  • image
  • report
