node-red-contrib-car-bmw 0.7.1
Node-RED nodes to connect to BMW ConnectedDrive and read infos of your car.
npm install node-red-contrib-car-bmw
Node-RED nodes for BMW ConnectedDrive
npm version
This package contains nodes to easily connect to BMW ConnectedDrive and read out informations about your vehicles.
NOTE: These nodes are unofficial and do NOT COME from BMW AG. Be careful when using these.
Be careful not to send your login and password to anyone other than BMW or you are giving away the authentication details required to control your car.
Also ensure that you don't overwhelm the BMW servers with requests. Calling REST APIs at very high frequency can put substantial load on the servers and might get your IP blocked by BMW.
Disclaimer
Use these nodes at your own risk. The authors do not guaranteed the proper functioning of these nodes. This code attempts to use the same interfaces used by the official BMW ConnectedDrive web portal. However, it is possible that use of this code may cause unexpected damage for which nobody but you are responsible. Use of these functions can change the settings on your car and may have negative consequences such as (but not limited to) reducing the available charge in the battery.
Install using the managed palette from inside Node-RED.
There are 3 new nodes which appear in the category 'BMW' in your Node-Red palette.
BMW List
Reads the list of cars, that are assigned to a BMW ConnectedDrive account.
Example Output:
    "vin": "WBA123456789",
    "mappingInfo": {
        "isAssociated": false,
        "isLmmEnabled": false,
        "mappingStatus": "CONFIRMED",
        "isPrimaryUser": true
    "appVehicleType": "CONNECTED",
    "attributes": {
        "lastFetched": "2023-07-30T16:06:26.864Z",
        "model": "330e",
        "year": 2021,
        "color": 4283783516,
        "brand": "BMW",
        "driveTrain": "PLUGIN_HYBRID",
        "headUnitType": "MGU",
        "headUnitRaw": "HU_MGU",
        "hmiVersion": "ID7",
        "softwareVersionCurrent": {
            "puStep": {
                "month": 3,
                "year": 23
            "iStep": 550,
            "seriesCluster": "S18A"
        "softwareVersionExFactory": {
            "puStep": {
                "month": 3,
                "year": 21
            "iStep": 530,
        "telematicsUnit": "ATM2",
        "bodyType": "G21",
        "countryOfOrigin": "DE",
        "driverGuideInfo": {
            "androidAppScheme": "com.bmwgroup.driversguide.row",
            "iosAppScheme": "bmwdriversguide:///open"
BMW Get
Read different informations about your car.
Example Output:
    "state": {
        "isLeftSteering": true,
        "lastFetched": "2023-07-30T15:51:17.326Z",
        "lastUpdatedAt": "2023-07-19T16:46:08Z",
        "isLscSupported": true,
        "range": 415,
        "doorsState": {
            "combinedSecurityState": "UNLOCKED",
            "leftFront": "CLOSED",
            "rightFront": "CLOSED",
            "combinedState": "CLOSED",
            "hood": "CLOSED",
            "trunk": "CLOSED"
        "windowsState": {
        "location": {
            "coordinates": {
                "latitude": xx.yy,
                "longitude": ac.dc
            "address": {
                "formatted": "Roßfeldstraße, 83471 Eck"
            "heading": 190
        "currentMileage": 72467,
        "requiredServices": [{
                "dateTime": "2023-10-01T00:00:00.000Z",
                "type": "BRAKE_FLUID",
                "status": "OK",
                "description": "Next service due by the specified date."
        "checkControlMessages": [{
                "type": "ENGINE_OIL",
                "severity": "LOW"
        "combustionFuelLevel": {
            "remainingFuelLiters": 37,
            "range": 415
        "driverPreferences": {
            "lscPrivacyMode": "OFF"
        "climateTimers": [{
                "isWeeklyTimer": false,
                "timerAction": "DEACTIVATE",
                "timerWeekDays": [],
                "departureTime": {
                    "hour": 7,
                    "minute": 0
                "isWeeklyTimer": true,
                "timerWeekDays": [
                    "MONDAY"
                "departureTime": {
                    "hour": 7,
                    "minute": 0
                "timerWeekDays": [
                    "MONDAY"
                "departureTime": {
                    "hour": 7,
                    "minute": 0
    "capabilities": {
        "a4aType": "BLUETOOTH",
        "climateNow": true,
        "isClimateTimerSupported": true,
        "climateTimerTrigger": "START_TIMER",
        "climateFunction": "VENTILATION",
        "horn": true,
        "isBmwChargingSupported": false,
        "isCarSharingSupported": false,
        "isChargeNowForBusinessSupported": false,
        "isChargingHistorySupported": false,
        "isChargingHospitalityEnabled": false,
        "isChargingLoudnessEnabled": false,
        "isChargingPlanSupported": false,
        "isChargingPowerLimitEnabled": false,
        "isChargingSettingsEnabled": false,
        "isChargingTargetSocEnabled": false,
        "isCustomerEsimSupported": false,
        "isDataPrivacyEnabled": false,
        "isDCSContractManagementSupported": false,
        "isEasyChargeEnabled": false,
        "isMiniChargingSupported": false,
        "isEvGoChargingSupported": false,
        "isRemoteHistoryDeletionSupported": false,
        "isRemoteEngineStartSupported": false,
        "isRemoteServicesActivationRequired": false,
        "isRemoteServicesBookingRequired": false,
        "isScanAndChargeSupported": false,
        "lastStateCallState": "ACTIVATED",
        "lights": true,
        "lock": true,
        "sendPoi": true,
        "unlock": true,
        "vehicleFinder": true,
        "vehicleStateSource": "LAST_STATE_CALL",
        "isRemoteHistorySupported": true,
        "isWifiHotspotServiceSupported": false,
        "isNonLscFeatureEnabled": false,
        "isSustainabilitySupported": false,
        "isSustainabilityAccumulatedViewEnabled": false,
        "specialThemeSupport": [],
        "isRemoteParkingSupported": false,
        "remoteChargingCommands": {},
        "isClimateTimerWeeklyActive": false,
        "digitalKey": {
            "state": "NOT_AVAILABLE",
            "vehicleSoftwareUpgradeRequired": false,
            "bookedServicePackage": "NONE"
        "isPersonalPictureUploadSupported": false,
        "isPlugAndChargeSupported": false,
        "isOptimizedChargingSupported": false
BMW Action
Can be used to trigger a remote service on the car. This includes:
  • Flash headlights
  • Blow horn
  • Lock door
  • Unlock door
  • Start climate
  • Stop climate
  • Find vehicle (Update location)
  • Start charging
  • Stop charging
  • Change charging mode (Immediate charging or delayed charging)
  • Change charging settings (Current limit for AC charging and charging target)
Additional Information
  • For these nodes to work you need a car with BMW ConnectedDrive support and remote services.
  • The different types of data that can be read depend on the type of car. Different cars support different services.
  • If you are getting an error response from the server with an 'http statusCode', then this code might be interpreted as follows:
    • 401: 'UNAUTHORIZED'
    • 404: 'NOT_FOUND'
    • 405: 'MOBILE_ACCESS_DISABLED'
    • 408: 'VEHICLE_UNAVAILABLE'
    • 423: 'ACCOUNT_LOCKED'
    • 429: 'TOO_MANY_REQUESTS'
    • 500: 'SERVER_ERROR'
    • 503: 'SERVICE_MAINTENANCE'
Release Notes
v0.7.0 - Captcha for token request
BMW introduced a new Captcha which now needs to be solved in order to login and to use the API.
Depending on your region, you will need a one-time token for the initial login that can be generated by solving a captcha.
Click one of the following links to obtain the token:
Paste it into the Captcha field in the config node, save, deploy the flow that is using this account. The token is valid only for a short period of time.
Also ensure that you enabled a persistent context storage in the settings of Node-RED to preserve the login state, or you will have to solve a new captcha after a restart. When multiple storages are configured, name the one to use in Storage.
v0.5.3 - Start / Stop Charging
There are 2 new actions that allow you to start and stop the charging of your car. The previous action called Charge Now is no longer supported by the API.
v0.5.1 - New Charging Features
It is now possible to read out the charging settings using the BMW Get node.
In addition, there are 2 new actions which allow to change the charging mode and charging settings.
For the Change Charging Mode action the payload body must contain the charge and climate timer details to which the charging mode should be changed. In this case the payload body must follow the object structure of the chargeAndClimateTimerDetail object returned by the BMW Get node for the data type Charging Profile.
For the Change Charging Settings action the payload body must contain the following properties:
    "chargingTarget": <value in percent>,
    "acLimitValue": <value in amps>
  • The chargingTarget must be a value between 20 and 100 in steps of 5.
  • The acLimitValue must be a value as returned by the chargingSettingsDetail.acLimit.values of the Charging Profile data type of the BMW Get node. Typical values are: 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 20, 32, ...
v0.5.0 - Upgrade to BMW v4 API
The version 0.5.0 introduced a major breaking change in order to upgrade to the new BMW v4 API endpoints. The old v1 version of the API is discontinuied by BMW. The returned data structure differs and mapping the data internally does not make much sense. Most data is similar but not all is the same.
Example of the structural changes:
New data path (V4) Old path (V1)
attributes.brand brand
attributes.model model
attributes.softwareVersionCurrent.iStep iStep
attributes.softwareVersionCurrent.puStep puStep
attributes.softwareVersionExFactory.iStep exFactoryILevel
attributes.softwareVersionExFactory.puStep exFactoryPUStep
attributes.year year
state.chargingProfile.chargingSettings.targetSoc status.chargingProfile.chargingSettings.targetSoc
state.currentMileage status.currentMileage.mileage
state.doorsState.combinedSecurityState (properties.areDoorsLocked ? "SECURED" : "OPEN")
state.doorsState.hood properties.doorsAndWindows.trunk
state.doorsState.leftFront properties.doorsAndWindows.doors.driverFront
state.doorsState.leftRear properties.doorsAndWindows.doors.driverRear
state.doorsState.rightFront properties.doorsAndWindows.doors.passengerFront
state.doorsState.rightRear properties.doorsAndWindows.doors.passengerRear
state.doorsState.trunk properties.doorsAndWindows.doors.hood
state.electricChargingState.chargingLevelPercent properties.chargingState.chargePercentage
state.electricChargingState.chargingStatus properties.chargingState.state
state.electricChargingState.chargingTarget status.chargingProfile.chargingSettings.targetSoc
state.electricChargingState.isChargerConnected properties.chargingState.isChargerConnected
state.electricChargingState.range properties.electricRange.distance.value
state.isLeftSteering ?
state.lastUpdatedAt status.lastUpdatedAt
state.location.address.formatted properties.vehicleLocation.address.formatted
state.location.coordinates.latitude properties.vehicleLocation.coordinates.latitude
state.location.coordinates.longitude properties.vehicleLocation.coordinates.longitude
state.location.heading properties.vehicleLocation.heading
state.roofState.roofState properties.doorsAndWindows.moonroof
state.windowsState.leftFront properties.doorsAndWindows.windows.driverFront
state.windowsState.leftRear properties.doorsAndWindows.windows.driverRear
state.windowsState.rightFront properties.doorsAndWindows.windows.passengerFront
state.windowsState.rightRear properties.doorsAndWindows.windows.passengerRear
vin vin
History
* 2017-Dez-01: 0.1.0 - First prototype.
* 2018-Jan-26: 0.1.1 - Remove verbose logging of token code.
* 2019-Jun-17: 0.1.2 - Added diagnosis message if VIN has invalid format.
* 2021-Sep-08: 0.2.0 - Refactored code to make token handling more stable. Token is no longer cached on disk.
                     - Added service to get statistics of last trip and all trips.
                     - Added service to get destinations.
                     - Added service to get car status.
                     - Fixed service to get charging profile.
                     - Server now selected by region.
* 2021-Oct-04: 0.3.0 - Added new node "BMW Action" to trigger a remote service on the car.
* 2022-Jan-22: 0.3.1 - Fix to support new API from "my BMW" (charging-statistics, charging-sessions).
* 2022-Jan-23: 0.3.2 - Added new remote command "Charge Now".
* 2022-Jan-23: 0.3.3 - Cleanup and additional error message.
* 2022-Mar-04: 0.4.0 - Add new authorization code from myBMW API.
* 2022-Mar-05: 0.4.1 - Minor cleanup of code and fix of error messages.
* 2022-May-30: 0.4.2 - Fix authentication error 403 due to new user-agent, thanks to @dzett and @jkellerer
* 2022-Jul-21: 0.4.4 - Make unit selectable between metric and imperial, thanks to @oemich
* 2022-Aug-07: 0.4.6 - fix region setting, thanks to @oemich
* 2023-Feb-12: 0.4.7 - fix "Climate Stop" action, thanks to @amuehlhause
* 2023-Jul-03: 0.5.0 - Adopt BMW APIv4 to fix http 404, thanks to @jkellerer
* 2023-Jul-30: 0.5.1 - Update readme with new return values of v4 and release notes
                     - Fix retrievel of charging profile and cleanup of source
                     - New experimental feature to set charging mode and settings
* 2023-Jul-31: 0.5.2 - Update readme additional information about charging features.
* 2023-Aug-05: 0.5.3 - Add actions to start and stop charging, thanks to @IfThenElseLoop
* 2024-Apr-15: 0.6.0 - Updated auth scheme and use V5 vehicle list. Thanks to @jkellerer.
                     - Fixes authentication errors with new BMW API.
* 2024-Dec-16: 0.7.0 - Fix: Add required captcha for API change. Thanks to @jkellerer.
* 2025-Sep-05: 0.7.1 - Fix: Create a unique & stable `X-User-Agent` header.
Credits
This project is heavily influenced by the work of:
Thanks for contributions from:
Trademarks
"BMW ConnectedDrive" is a registered trademark of BMW AG.
Licenses
The MIT License (MIT)
Copyright (c) 2017-2024 sebakrau ([email protected]), jkellerer
BSD 2-Clause License
Copyright (c) 2017, Nils Schneider All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
  • Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
  • Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Version: 0.7.1
Updated 1 year, 3 months ago
Rating: 4.6 11
41 in the last week
  • car-bmw
  • car-bmw-list
  • car-bmw-get
  • car-bmw-action
  • BMW
  • ConnectedDrive
  • Remote Services
  • www.bmw-connecteddrive.de/
  • www.bmw-connecteddrive.com/
