node-red-contrib-canopen-mcan 0.6.6
Node-RED Nodes for CANopen modules
npm install node-red-contrib-canopen-mcan
Node-RED Nodes for MicroControl CANopen devices
With these Nodes you can connect MicroControl CANopen modules to Node-RED.
Requirements
  • µMIC.200 controller
  • CANopen server daemon (Comet)
Supported devices
Currently the following CANopen devices are supported by this plugin:
  • µCAN.4.ai-BOX
  • µCAN.4.ao-BOX
  • µCAN.4.ti-BOX
  • µCAN.8.dio-BOX
  • µCAN.8.pwm-BOX
How to use
A single node represents either an input or an output of a CANopen device. As such, a node has only either one input or one output. After dragging a node to the flow you need to configure the CAN interface, node-ID and channel number.
Node configuration
A node is defined by the following properties:
  • CAN channel - i.e. the used CAN interface on the µMIC.200 controller
  • Node ID - i.e. the CANopen device address setting
  • Input / Output channel - i.e. the input or output connected for the signal
image Configuration
Version: 0.6.6
Updated 6 years, 11 months ago
5 in the last week
  • mcan-ai
  • mcan-dio in
  • mcan-ti
  • mcan-ao
  • mcan-dio out
  • mcan-pwm
  • CANopen
  • MicroControl
