node-red-contrib-calc-next-work-days 0.0.6
Сalculation of the following working days based on the holidays array
npm install node-red-contrib-calc-next-work-days
NPM
Build npm
README
Node for Node-RED.
A simple node that calculates the next (or several) working day given the holidays and working weekends days. For calculates dates used Moment.js
Install latest release: npm i -g node-red-contrib-calc-next-work-days
Inputs
msg.date date
The start date for calculation(this day is counted as the first). Pass by upstream mode.
msg.countworkdays number
Number of working days to be calculated in result. You can specify in the configuration node or passed by upstream mode.
msg.holidays array
Array of dates with holidays
msg.workweekends array
Array of dates with working weekends days. Not required.
msg.typeweekend string
Weekend type. You can specify in the configuration node or passed by upstream mode. satsun, frisat or withoutweekends values.
Outputs
msg.workdays Array of arrays
Result. Array of arrays the following working days.The count will be equal to msg.countworkdays
The first element contains the calculated date
The second element contains the day number relative to the primary date
Example:
msg.workdays array
0: array 0: "2018-05-10T00:00:00.000Z" calculated date 1: 1 number of day
1: array 0: "2018-05-11T00:00:00.000Z" calculated date 1: 2 number of day
2: array 0: "2018-05-14T00:00:00.000Z" calculated date 1: 3 number of day
Details
msg.payload Not affected or processed. The output remains the same.
msg.holidays Array of dates with holidays. Dates must be in javascript date format. Example ["2018-05-01 00:00:00.000Z","2018-05-02 00:00:00.000Z"]
msg.workweekends Array of dates with working weekends days. Dates must be in javascript date format.
Example ["2018-05-12 00:00:00.000Z","2018-05-13 00:00:00.000Z"] This array can be empty. Then the calculation will be made considering the holidays and usual weekends days sets in "Weekends days" section.
msg.workdays Calculated result. Array with calculated working days. The number of elements (days) is equal to that set in msg.countworkdays.
Version: 0.0.6
7 in the last week
  • calc-next-work-days
  • holiday
  • calculate
  • calculate working days
  • workdays
  • calc next work days
