node-red-contrib-c2nred-mqtt 0.2.1
Node Red MQTT broker node based on aedes.js for CLICK C2-NRED module
npm install node-red-contrib-c2nred-mqtt
MQTT Broker for CLICK C2-NRED Node-RED modules based on node-red-contrib-aedes which is based on Aedes.
You can use the MQTT protocol in Node-RED without an external MQTT broker like Mosquitto.
Node.js CI js-semistandard-style Codacy Badge
Open Source Love
Background
This node was created because the node-red-contrib-aedes MQTT Broker had a dependency of a dependency that did not work for the C2-NRED module.
You can install the node directly within the editor by using the Palette Manager.
Flows
Just put this node on Node-RED and hit the deploy button. The MQTT Broker will run on your Node-RED instance. flows
  • Works with AutomationDirect.com CLICK C2-NRED module
  • Standard TCP Support
  • WebSocket Support via port or path
  • SSL / TLS
  • Message Persistence (In-memory, LevelDB or MongoDB)
For more information see AutomationDirect.com C2-NRED GitHub
Server without public IP or behind firewall
If your server is behind a firewall or you cannot open any ports other than the standard http/https ports, the MQTT broker node can be accessible by public clients through a WebSocket path.
When your Node-RED server address is https://yourserver/, you can set the WebSocket to bind to, e.g., "/ws/mqtt" path, to have wss://yourserver/ws/mqtt WebSocket at port 443.
You can also bind the WebSocket to the root "/" path and having wss://yourserver/ WebSocket listening at port 443 (or ws://yourserver/ at port 80).
Licensed under MIT.
Version: 0.2.1
Updated 8 months, 3 weeks ago
195 in the last week
  • c2nred broker
  • aedes
  • mqtt
  • c2nred
  • click
  • Trevis Walker
  • Andrew Garcha
