node-red-contrib-button-morse 2.0.0
Timing of Button down/up events, returning press sequence information (Morse code)
npm install node-red-contrib-button-morse
A Node-RED node that times button presses and decodes them as Morse code (dots, letter, word, sentence, text). Long presses can also be used as actions (e.g. reboot or shutdown on a Raspberry Pi).
From your Node-RED user directory (usually ~/.node-red):
Requires Node-RED 3.0 or newer and Node.js 18 or newer.
Input
msg.payload: 0 = button down, 1 = button up (pull-up wiring). true/false and "0"/"1" also work. Tick Invert if your button reports down as 1.
Debounce the input before it reaches this node. Repeated identical states are ignored.
Setting Default Meaning
Dot length 333 ms Base timing unit. A press longer than 1.5 dots is a dash. A pause of 3 dots ends a letter, 7 ends a word, 12 ends a sentence, 50 clears the history.
Progress on Send progress_* / *_end messages as timers pass.
Invert off Treat 1 as down and 0 as up.
Feedback off Play back each letter and/or Blink when a long-press step is reached, as 1/0 on an extra output.
Long press hold 3 s, todo 7 s, quiet 10 s, reboot 12.5 s, shutdown 15 s, nop 20 s Your own list of long-press steps (seconds + name).
Outputs off One extra output per long-press step, carrying its action_<name> message.
Personalizing long presses
Open the node and edit the Long press list: each step has a time in seconds and a name. While the button is held, each step sends progress_<name> as it is reached. When the button is released, action_<name> is sent for the last step reached. Names are turned into topics by lower-casing and replacing other characters with _, so Wi-Fi becomes action_wi_fi. The dialog shows the topic next to each step.
  • Tick Outputs to get one output per step, and wire e.g. reboot straight to an Exec node.
  • Tick Blink when a long-press step is reached so the user can count blinks to know when to release.
  • Make the last step harmless (e.g. cancel) so that holding longer cancels.
  • Defaults restores the built-in list.
Feedback output
With a Feedback option ticked, output 2 sends msg.payload 1/0. Wire it to a GPIO output with an LED or buzzer. Each letter you key is played back after the letter pause, and each long-press step gives a short blink. Feedback stops as soon as the button is pressed again.
Output messages
Output 1 carries all events, and msg.topic tells you what happened:
  1. Button pressed/released: button_down, button_up.
  2. While the button is held, a progress message is sent each time a new timer is reached: progress_short_press, progress_long_press, then progress_<name> for each long-press step (by default progress_hold (3 s), progress_todo (7 s), progress_quiet (10 s), progress_reboot (12.5 s), progress_shutdown (15 s), progress_nop (20 s)).
  3. When the button is released, the last reached timer is sent as an action: action_short_press, action_long_press or action_<name> (e.g. action_reboot).
  4. While the button is released, progress messages are sent as pauses pass: letter_end, word_end, sentence_end, clear_history.
  5. On the next press, the finished pause is sent as an action: action_no_space, action_end_of_letter, action_end_of_word, action_end_of_sentence, action_clear_history.
Example message:
  "topic": "sentence_end",
  "payload": {
    "dots": "... ___ ...",
    "text": "sos",
    "sentence": "sos",
    "word": "sos",
    "letter": "s",
    "history": [],
    "state": "up",
    "token": "   ",
    "time": 3996
In dots, letters are separated by a thin space ( ) and words by a normal space. history holds the text of earlier sentences until clear_history. Eight dots (........) erase the previous word.
Using the output
Send the output to a Switch node on msg.topic, for example:
  1. action_reboot → Exec sudo shutdown -r now
  2. action_shutdown → Exec sudo shutdown -h now
  3. sentence_end → another Switch on msg.payload.sentence to react to specific words
Trying it without a Raspberry Pi
The node only reads msg.payload, so it runs on any Node-RED install. Import Menu → Import → Examples → node-red-contrib-button-morse → button-morse-test. It has two Inject nodes, down and up: click down then up for one button press. Dot length is set to 1000 ms so you can click comfortably. The decoded text is shown in the Debug sidebar and under the Debug nodes.
On a Raspberry Pi, replace the two Inject nodes with a GPIO input node.
Examples
Import them from Menu → Import → Examples → node-red-contrib-button-morse:
Example Shows
button-morse-test Try the node on any computer: click Inject nodes down / up as the button.
raspberry-pi-gpio A real button on GPIO17 (physical pin 11) with the internal pull-up and debounce, and a feedback LED on GPIO18 (pin 12).
long-press-actions Personal long-press steps (quiet / reboot / shutdown / cancel), one output each, a blink per step. The Exec nodes only echo until you change them.
morse-commands Spell on, off or sos to switch an LED or send an alert, with letter playback on output 2.
Upgrading from 1.x
  • The node now works as a real Node-RED node; 1.x was a Function-node body and did not run.
  • No custom contextStorage setup is needed any more.
  • Dot length is set in the node's edit dialog (dotLength), not in context.
  • Words in text are now separated by spaces, and payload.history was added.
  • Long-press steps are configurable. Default topics are lower-case as before (action_quiet, ...). A long press now shows as ~ in dots and ends the current letter.
Development
npm install
npm test
ISC. Created by Erik Johansen, 2021.
Version: 2.0.0
Updated 2 days ago
  • button-morse
  • button
  • morse
  • gpio
