node-red-contrib-buffer-to-png 4.0.0
[Node-RED](http://nodered.org) node to convert a buffer to png.
npm install node-red-contrib-buffer-to-png
Convert a buffer to a png
or from Manage Palette, search node-red-contrib-buffer-to-png.
This node should be provided in input :
  • msg.buffer: the buffer to convert. Format: Buffer.
  • msg.filename: the filename for the png file. Format: String.
This node will give an output in msg.payload, with the keys: :
  • png : the converted buffer into Jimp png instance. Format: Jimp png instance.
  • png_buffer : the converted Jimp png instance into buffer. Format: Buffer.
  • png_url : the url where the .png file was saved. Format: String.
  • png_url_path : the url of the folder where the .png file was saved. Format: String.
  • png_filename : the filename of the saved .png file. Format: String.
Contributing
For simple typos and fixes please just raise an issue pointing out our mistakes. If you need to raise a pull request please read our contribution guidelines before doing so.
Copyright and license
Copyright 2022 IBM Corp. under the Apache 2.0 license.
Version: 4.0.0
Updated 3 years, 5 months ago
License: Apache 2.0 license
Rating: 2.0 1
25 in the last week
  • buffer-to-png
  • image
  • png
  • buffer
  • Paula Farias
