node-red-contrib-bsb-lan 1.2.1
A node-red node that makes the communication with BSB-Lan very easy
npm install node-red-contrib-bsb-lan
CLA assistant compile CodeFactor npm version
node-red-contrib-bsb-lan a BSB-LAN node for Node-RED
Provides functionality to retrieve data from the BSB-LAN adapter.
When triggered, the node will login and make the configured request.
This is an sample request of fetching (GET) two parameters:
    "_msgid": "...",
    "payload": {
        "700": {
            "name": "Betriebsart",
            "error": 0,
            "value": "1",
            "desc": "Automatik",
            "dataType": 1,
            "readonly": 0,
            "unit": ""
        "710": {
            "name": "Komfortsollwert",
            "error": 0,
            "value": "22.0",
            "desc": "",
            "dataType": 0,
            "readonly": 0,
            "unit": "°C"
Install via the palette manage in the Node-RED admin ui (no restart needed).
Alternatively run the following command in your Node-RED user directory (typically ~/.node-red):
then restart Node-RED and add an instance of the bsb-lan node.
Just add the connection settings and select what type of request you want to sent.
You can also override the configuration settings with properties that are injected into the incomig message.
property type example
requesttype GET / SET / INF GET
parameters [] [700,710] (fetched in GET the parameter 700 & 710)
value number 22.0 (only valid for requesttype SET / INF)
GET
With the GET you can fetch multiple parameters in on request. Just select in the parameters tree the parameter that you like to fetch and inject a message.
config
The payload will be filled with the values.
SET / INF
You can even change the configuration of your device but you have to first enable in the BSB-LAN the write functionality see Chapter 5
Select the right request type and now you can select only one value from the parameter list. Fill in the value that you want to write into the parameter and inject a message.
Version: 1.2.1
Updated 3 years, 5 months ago
Rating: 5.0 2
11 in the last week
  • bsb-lan
  • bsb-lan-device
  • bsb-lan
