node-red-contrib-bravia2 2.2.3
A Node-RED node to control Sony BRAVIA Android TVs.
npm install node-red-contrib-bravia2
npm version npm downloads CI Node.js Version License
Node-RED nodes to control Sony BRAVIA Android TVs.
  • Control Node - Simple way to control basic TV functions (power, volume, input) with a single compound message
  • API Node - Full access to the Sony BRAVIA REST API for advanced use cases
  • IRCC Node - Send remote control commands (power, volume, navigation, etc.)
  • Auto-discovery - Automatically discover TVs on your network
  • Modern codebase - Native fetch, async/await, zero vulnerabilities
Requirements
  • Node.js >= 18.0.0
  • Node-RED >= 3.0.0
  • Sony BRAVIA Android TV with IP Control enabled
Or install via the Node-RED palette manager.
TV Setup
  1. Turn on your TV
  2. Go to Settings > Network > Home network setup > Remote device/Renderer > On
  3. Go to Settings > Network > Home network setup > IP Control > Authentication > Normal and Pre-Shared Key
  4. Go to Settings > Network > Home network setup > Remote device/Renderer > Enter Pre-Shared Key and set your PSK (e.g., 0000)
  5. Go to Settings > Network > Home network setup > Remote device/Renderer > Simple IP Control > On
bravia-tv (Config)
Configuration node for your TV connection. Set the hostname/IP, port (default: 80), and PSK.
bravia-control
Bidirectional node that polls TV status and accepts commands.
Polling: Configurable interval (1s to 1h) with selectable status items:
  • Power status (always polled)
  • Volume/mute level
  • Input source
Features:
  • Built-in RBE (Report by Exception) - only outputs on change
  • Skip-if-busy prevents request pileup
Input: msg.payload - JSON object with commands:
{"power": true, "volume": 30, "input": "hdmi1"}
Output: msg.payload - Current TV state in same format
bravia-api
Call any Sony BRAVIA API method directly.
Input:
  • msg.method - Method in format protocol:version:method (e.g., system:1.0:getPowerStatus)
  • msg.payload - Optional JSON payload for the method
Output: msg.payload - API response
bravia-ircc
Send IRCC (IR-like) commands to control the TV. Commands can be specified by name (e.g., VolumeUp, Home, Hdmi1) or as raw IRCC codes.
Input: msg.payload - Command name or comma-separated list of commands
Credits
This project is a modernized fork of node-red-contrib-bravia, originally created by Wayne Haffenden.
The original implementation provided the foundation for controlling Sony BRAVIA TVs from Node-RED. This fork updates the codebase to modern Node.js standards and removes deprecated dependencies.
Release Process
This project uses release-please for automated releases. The workflow:
  1. Push commits to main using Conventional Commits format
  2. Release-please automatically creates/updates a release PR with changelog
  3. Merge the release PR to trigger npm publish
Do NOT manually create tags or bump versions in package.json.
MIT
Version: 2.2.3
Updated 10 months, 3 weeks ago
620 in the last week
  • bravia-tv
  • bravia-ircc
  • bravia-api
  • bravia-control
  • sony
  • bravia
  • tv
  • iot
  • android
  • androidtv
  • Wayne Haffenden
