node-red-contrib-brain-js 0.0.1
This node provides neural networks using brain.js
npm install node-red-contrib-brain-js
This node provides neural networks. It is based on brain.js
From your node-red directory:
or
in the Node-red, Manage palette, Install node-red-contrib-brain-js
At first you need to see the brain.js documentation
The following neural networks are available :
Training
The training data need to be stored in msg.trainData and the format is described here.
The network options can be provided in msg.neuralNetworkOptions.
When the training is done, the network is available in msg.net and can be stored to be imported next time.
Run
The running data need to be stored in msg.runData.
The result is available in msg.decision.
Import network
When the input message contains msg.netJSON, the network is loaded from the JSON provided.
MIT License
Version: 0.0.1
Updated 8 years, 1 month ago
5 in the last week
  • neuralnet
  • neural network
  • ai
  • machine learning
  • brain.js
