node-red-contrib-boolean-logic-plus 0.1.5
AND/OR/XOR boolean logic across a fixed number of topics, with a second output reporting which topics currently hold true.
npm install node-red-contrib-boolean-logic-plus
AND/OR/XOR boolean logic across a fixed number of distinct topics - the same behaviour as the original node-red-contrib-boolean-logic, with a second output added that reports the current true/false breakdown across every configured topic.
This is an independent implementation matching the documented behaviour of the original, not a fork of its source, released separately under Apache-2.0.
Or use Manage Palette in the Node-RED editor.
Configure:
  • Operation - And / Or / Exclusive Or
  • Number of topics - how many distinct msg.topic values to expect
  • Topic - the topic set on outgoing result messages
  • Invert - flip the final result (AND->NAND, OR->NOR, XOR->XNOR)
  • Name - optional
Feed it messages with different msg.topic values. It waits until it's seen a value for every configured topic at least once, then re-evaluates and outputs on every subsequent message. If a distinct topic beyond the configured number ever arrives, it resets silently (no output) and waits for a fresh full set.
Output 1: result
{ topic: "result", payload: true }
Reflects Invert if enabled - this is the final result.
Output 2: true/false breakdown
An object listing which configured topics currently hold true and which hold false - always the raw states, regardless of Invert:
{ topic: "result", payload: { true: ["D", "E"], false: ["A", "B", "C"] } }
Only sent when the breakdown actually changes from the last time it was sent - not on every evaluation, and not merely because the boolean result on output 1 flipped while the underlying topics stayed the same.
Node label
Shows the operation and topic count, e.g. OR [2] - with your Name appended in brackets if you've set one, e.g. OR [2] (garden lights).
Status
Shows a dot colored green (true) or red (false), with the matching group listed first: true: D, E. false: A, B, C when the result is true, or false: A, B, C. true: D, E when it's false. Either group is omitted if empty. While still priming: 3 of 4 topics received: A, B, C - so you can see exactly which topic is missing, not just the count. After a reset: unknown.
Value conversion
Booleans are taken as-is. Numbers: 0 is false, anything else is true. Strings that parse as a decimal number follow the same rule; the string "true" (case-insensitive) is true; anything else is false.
Exclusive Or with more than 2 topics
Matches the original: true only when exactly one topic is currently true - not "an odd number are true". With 3+ topics all true, XOR is false, same as the original.
Apache-2.0
Version: 0.1.5
Updated 4 months ago
  • boolean-logic-plus
  • boolean
  • logic
  • and
  • or
  • xor
  • utility
