node-red-contrib-blindcontroller-v3 3.0.0
Node-RED nodes for automated control of roller blinds based on sun position and weather conditions (Node.js v22+ compatible, 0-100% cloud coverage, and persistent season mode).
npm install node-red-contrib-blindcontroller-v3
A updated fork of node-red-contrib-blindcontroller (originally created by Alisdair Smyth) updated for Node.js v22+, 0–100% cloud coverage, persistent season mode, and accurate status pill reporting.
What's New in v3.0.0
  • 0–100% Cloud Coverage Support: Accepts standard 0–100 cloud cover percentages directly in both msg.payload.clouds and the node's Cloud Cover (%) threshold—no / 100 math required for Home Assistant or modern weather integrations.
  • Node.js v22+ Compatibility: Guards all internal array iterations against Array.prototype extensions (Missing property: function (array) fix) and fixes boolean checkbox validation in the node editor UI.
  • Accurate Status Pill Output: Displays the actual output percentage (honoring the "0 is Closed" inversion setting) alongside the active season mode (e.g., Winter • 100% or Summer • 64%).
  • Persistent Summer / Winter Mode: Stores runtime mode updates in node.context() so your active season survives flow redeploys automatically, and survives full Node-RED / Home Assistant restarts when localfilesystem context storage is enabled.
Migration & Installation
Because this package registers the same blindcontroller and multiblindcontroller node types so your existing flows migrate seamlessly without rebuilding:
  1. Uninstall any previous version first (node-red-contrib-blindcontroller or node-red-contrib-blindcontroller-v2) via Manage Palette or npm uninstall.
  2. Install node-red-contrib-blindcontroller-v3 via Manage Palette → Install or npm install node-red-contrib-blindcontroller-v3.
  3. Restart Node-RED.
(Note: If you previously divided cloud coverage by 100 or used a decimal threshold like 0.86, update your cloudsthreshold to a 0–100 percentage such as 86 and pass 0–100 cloud coverage directly.)
Correct Flow Wiring (Parallel Inputs)
Do NOT chain Weather into sunpos in series. sunpos overwrites msg.topic and msg.payload, which discards any upstream weather properties. Wire sunpos (topic: "sun") and your weather payload (topic: "weather") in parallel into Blind Controller:
[10M Timer] ──┬──► [sunpos (topic: "sun")] ──────────────────┐
              └──► [Weather Source (topic: "weather")] ──────┼──► [Blind Controller]
Home Assistant Weather Wiring Tip
If you use a Home Assistant current state node (weather.*), you can pass cloud_coverage (0–100) directly to blindcontroller by setting its output properties to:
  • msg.topic = "weather" (string)
  • msg.payload.clouds = data.attributes.cloud_coverage (JSONata / expression)
Season Mode Persistence Across Reboots
Runtime topic: "mode" messages ({ "mode": "Winter" } or { "mode": "Summer" }) are saved in node.context():
  • Flow Redeploys: Persists automatically out of the box.
  • Full Node-RED / Home Assistant Restarts: Enable localfilesystem context storage in your Node-RED settings.js:
    contextStorage: {
        default: {
            module: "localfilesystem"
    (If localfilesystem is not enabled, the node safely falls back to its configured default mode on startup.)
Apache-2.0 — Original work Copyright 2015, 2016 Alisdair Smyth; modifications Copyright 2026 Kolitar J'Odan.
Version: 3.0.0
Updated 15 hours ago
  • blindcontroller
  • multiblindcontroller
  • blind
  • blinds
  • roller
  • shutter
  • shade
  • sun
  • sunpos
  • automation
  • home-assistant
  • nodejs-22
  • Kolitar J'Odan
