node-red-contrib-ble-sense 0.0.13
Node-RED module for Bluetooth Low Energy (BLE) devices.
npm install node-red-contrib-ble-sense
Node-RED central module for Bluetooth Low Energy (BLE) devices. Speficially designed to connect microcontrollers such as Arduino Nano 33 BLE Sense but should be working well with other central devices.
Example peripheral codes are provided in examples folder.
You MUST USE SAME UUIDs that are given in example scripts to convert received data.
hci0 is accepted as default adapter. Multiple adapter support will be added later.
Permissions
To run without sudo run the following:
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
This grants the node binary cap_net_raw privileges, so it can start/stop BLE advertising.
Prerequisite
Requires @abandonware/noble: 1.9.2-20..
Quick Start
The package contains two nodes: BLE Scanner, BLE Connect.
BLE Scanner node allows you to scan BLE devices. A message with start as a topic starts scanning. The node can output the following:
  • Whole peripheral as an object.
  • The MAC address of the peripheral.
  • The advertisement data as a buffer array.
Hence BLE Scanner node can be used as an observer. This node also allows you to configure and search for a specific peripheral via given name. To stop scanning a message with stop topic should be given.
BLE Connect node provides direct connection to the peripheral. This node must not be used alone. The scanning should be in progress to establish a connection. It takes JSON Object as an input. The service and characteristics UUIDs should be provided. If not, it will try to subscribe all advertised characteristics.
The example input is shown below:
    "services": [
        "181a"
    "characteristics": [
        "2a6e",
        "2a6f",
        "2a6d"
More details are provided in Node-RED node information panel.
Examples
An example flow that provides subscription to the all characteristics is given below.
Licensed under the MIT License.
Cite
Please cite the following work if you use this package academically.
@article{KAYAN2021100437,
title = {AnoML-IoT: An end to end re-configurable multi-protocol anomaly detection pipeline for Internet of Things},
journal = {Internet of Things},
pages = {100437},
year = {2021},
issn = {2542-6605},
doi = {https://doi.org/10.1016/j.iot.2021.100437},
url = {https://www.sciencedirect.com/science/article/pii/S2542660521000810},
author = {Hakan Kayan and Yasar Majib and Wael Alsafery and Mahmoud Barhamgi and Charith Perera}
Latest Update Notes
  • Fixed the random connection drops.
  • Fixed the wrong node status for the scanner node.
  • Dependencies are updated.
  • Code is less spaghetti.
Known Bugs
  • Bluetooth adapter state event is not properly emitted during initialization.
Version: 0.0.13
Rating: 4.9 11
28 in the last week
  • BLE Scanner
  • BLE Connect
  • Bluetooth Low Energy
  • Bluetooth
  • Arduino
  • Arduino Nano 33 BLE Sense
  • noble
