node-red-contrib-ble-scanner 0.2.0
Generic Node-RED BLE scanner for raw advertisement manufacturer data.
npm install node-red-contrib-ble-scanner
Strict TypeScript Node.js library, CLI, and Node-RED nodes for collecting raw Bluetooth LE advertisement manufacturer data.
The package supports two BLE backend implementations:
  • auto: uses BlueZ on Linux when available, otherwise noble
  • bluez: uses Linux BlueZ over D-Bus
  • noble: uses @abandonware/noble
The scanner does not connect to BLE devices and does not parse or decrypt device-specific payloads. It listens for BLE advertisements and returns the raw manufacturer data bytes.
Library
The package exports a typed ESM API from dist/index.js:
  • discoverDevices(options) returns matching BLE devices
  • readDevices(options) listens for matching advertisements and collects raw manufacturer data
  • readDevice(device, options) reads advertisements for one discovered device
  • shutdownBluetooth() stops active BLE scans
Each reading contains device metadata, a timestamp, and a messages array. Every raw message includes the company id, original Buffer as data, plus hex, base64, bytes, length, and timestamp.
import { readDevices } from 'node-red-contrib-ble-scanner';
const readings = await readDevices({
  deviceName: 'My BLE Device',
  listenMs: 5000
console.log(readings.flatMap((reading) => reading.messages.map((message) => message.hex)));
  • ble-reader-device: config node for BLE advertisement scanning, device selection, and filters
  • ble-reader-read: input node that collects raw manufacturer data
Use the config node's search button to discover devices from the Node-RED editor. Select one exact advertised device name, or keep "All discovered devices".
The output is placed in msg.payload as an array with zero, one, or multiple readings.
Incoming msg.payload may contain { deviceName, listenMs, serviceUuid } to override the configured values for one read.
CLI
npm install
npm run build
npm run discover
npm run read
Useful options:
node ./bin/ble-reader.js discover
node ./bin/ble-reader.js discover --name-prefix SK
node ./bin/ble-reader.js discover --service-uuid fff0
node ./bin/ble-reader.js read "My BLE Device" --listen-ms 5000
node ./bin/ble-reader.js read --bluetooth bluez --debug
node ./bin/ble-reader.js read "My BLE Device" --interval 5
read --interval 5 repeats an advertisement scan every five seconds until stopped.
Development
npm run build
npm run lint
npm test
npm run check
Version: 0.2.0
Updated 5 months, 3 weeks ago
137 in the last week
  • ble-reader-device
  • ble-reader-read
  • bluetooth
  • ble
  • scanner
  • advertisements
  • manufacturer-data
