node-red-contrib-bitfinex 0.4.0
Bitfinex API wrapper node for node-red
npm install node-red-contrib-bitfinex
Bitfinex Function Node for Node-RED
npm version
node-red-contrib-bitfinex make Bitfinex API very easy to access, you can visually show exchange data in node-red's dashboard, mashup with other services, or trade from weird objects around your house.
  1. Install Node-RED npm install -g node-red
  2. Go to Node-RED user directory (default: ~/.node-red)
  3. npm install node-red-contrib-bitfinex
Or start Node-RED via node-red, then go settings > Palette > Install tab in node-red and search bitfinex to install this module.
Imgur
  • A credential configuration block
Imgur
  • Installed Blocks are provide in bitfinex category
  • Guides and workable rest/websocket examples are provided in help tab
  • expose rest method in function block to easy access REST API calls.
Imgur
Imgur
  • expose bfx method in function block that allows advanced usage.
  • rest, ws returned data are auto transformed to object based on bfx-api-node-models
  • The functoin block supports multiple outputs (ex: can subscribe multiple tickers and export at the same block)
Imgur
Imgur
Refer official Bitfinex document https://docs.bitfinex.com/v2/docs for all APIs.
Bitfinex API credentials can be obtained from https://www.bitfinex.com/api
Credit
The block is derived from node-red's build-in function block. And refer node-red-contrib-aws-sdk for the credential block.
The functions are build on top of Bitfinex's nodejs API library
MIT License
Version: 0.4.0
Updated 6 years, 11 months ago
6 in the last week
  • bitfinex-credentials
  • Bitfinex function
  • bitfinex
  • cryptocurrency
  • crypto
  • exchange
