node-red-contrib-binarybuffer-utf8 0.0.3
A node which encode a utf16-le into utf8 string
Either use the Node-RED Menu - Manage Palette - Install, or run the following command in your Node-RED user directory - typically ~/.node-red
npm i node-red-contrib-binarybuffer-utf8
A node that converts an utf16-le binary buffer into a utf8 string which can be used in Node-RED. This node can be used e.g. for encode a tail node.
