node-red-contrib-better-ldap-servicely 0.1.7
A better node for LDAP communication.
npm install node-red-contrib-better-ldap-servicely
Open Source Love
Better LDAP includes nodes which implement the ldapjs api. Some nodes have been simplified to help ease of use. Time has been taken to make sure that the only dependency is ldapjs. This does make the code a bit more complex but I feel it enables a better cleaner project.
This is the servicely version for our node-RED integrations.
Or add via Manage Palette
Update Node
Update node is used to update an attribute on an LDAP object by DN
update_node update node settings
Operation, DN, Attribute, and Value can be accessed via msg.operation, msg.dn, msg.attribute, msg.payload respectively.
Node sets msg.ldapStatus with the result of operation.
Search Node
search_node search node settings
Search node is used to run a search query against a LDAP server. You must use a standard LDAP filter query. More information on ldap queries can be found here
Properties
Base DN the base LDAP object to start your search
Scope Scope can be either base, one, or sub
  • base - Only search the base dn. no further sub directories
  • one - Search only one directory down from the base dn
  • sub - Search all directories and sub directories
filter LDAP filter criteria
attributes Attributes to be returned for each object. A comma separated list of attributes to change. Default attributes are defined. They are targeted toward user queries. Provide
Defaults:
dn, userPrincipalName, sAMAccountName, objectSID, mail, lockoutTime, whenCreated, pwdLastSet, userAccountControl, employeeID, sn, givenName, initials, cn, displayName, comment, description, title, department, company
If you wanted to search for all objects where firstName starts with te you would use the filter (firstName=te*) where te is the search term and * is a wild card.
Host, port, username, and password are required to configure a new LDAP client. Noting special is required at for ldap connection. At this time a TLS connection is not available. If I get enough requests and someone willing ot test it I am more than happy to add the feature.
configuration settings
See license
Version: 0.1.7
Updated 4 years, 5 months ago
Rating: 4.0 1
2 in the last week
  • ldap-add in
  • ldap-del in
  • ldap-update in
  • ldap-search in
  • ldap
  • better
  • ldap
  • activedirectory
  • redconnect
