node-red-contrib-beckhoff-nodes 0.0.7
Custom Node-RED nodes for Beckhoff BK9100 bus couplers
npm install node-red-contrib-beckhoff-nodes
Node-RED nodes for Beckhoff BK9100 bus couplers via Modbus TCP. Read and control Beckhoff KL-series I/O modules for building automation and industrial control.
Or install via Node-RED palette manager.
Supported Cards
Card Type Channels
KL1804/08 Digital Input 4/8
KL2404/08 Digital Output 4/8
KL3204/08 Temperature Input 4/8
KL3464/68 Voltage Input (0-10V) 4/8
Quick Start
  1. Add BK9100 node to your flow
  2. Configure IP address and port (default: 502)
  3. Add cards and set poll rate (default: 1000ms)
  4. Connect outputs to process data
Reading Inputs
Each channel outputs separately:
  topic: "KL1808/ch3",
  payload: {
    channel: 3,
    value: true
Controlling Outputs
Topic-based:
msg.topic = "KL2408/ch5";
msg.payload = true;  // or false, 1, 0, "on", "off"
Object-based:
msg.payload = {
  card: "KL2408",
  channel: 5,
  value: true
Temperature Sensors (KL3204/08)
Configure sensor type per channel (Pt1000, Ni1000, NTC):
  topic: "KL3208/ch2",
  payload: {
    channel: 2,
    celsius: 22.45,
    fahrenheit: 72.41,
    ok: true
Voltage Inputs (KL3464/68)
Configure range (0-10V, 0.5-10V, 2-10V):
  topic: "KL3468/ch1",
  payload: {
    channel: 1,
    voltage: 7.35,
    percentage: 73.5
Global Settings:
  • IP Address, Port, Unit ID
  • Poll Rate (ms) for inputs
Per-Card Settings:
  • Custom poll rate (optional)
  • Output cards: Poll states and read-back after write
  • Temperature cards: Sensor type per channel
  • Voltage cards: Range and manufacturer per channel
MIT
Support
Report issues at GitHub
Version: 0.0.7
Updated 1 year, 1 month ago
259 in the last week
  • BK9100
  • beckhoff
  • bk9100
  • modbus
  • automation
  • industrial
