node-red-contrib-barcode 0.0.3
A Node-RED project with Dynamsoft Barcode Reader for Windows.
npm install node-red-contrib-barcode
Node-RED node with Dynamsoft Barcode Reader for Windows.
sudo npm install -g --unsafe-perm node-red
cd %userprofile%\.node-red
SDK License
Get the free trial license.
For example:
t0068NQAAACqUjZa21C+W7fRdPkf2FRFRr+QpfVC2tDsl/8t25TzYCNxl5s0OkuwFgEMGNfN95Z0HYQ55ROi1px9JqVAP7/c=
If the default port 1880 cannot work, change it to 18800 in %userprofile%\.node-red\settings.js.
Start Node RED:
node-red
In web editor, add inject node, file node, barcode node and debug node. You can set the image path in file node.
Node RED barcode
Click barcode node to set a valid license and barcode parameter template:
Barcode license
Here is an example of template:
  "ImageParameter": {
    "Name": "Custom_143301_827",
    "BarcodeFormatIds": [
      "OneD"
If you do not set a template, the default template will be used.
Run the app:
Node RED barcode results
Version: 0.0.3
Updated 8 years, 8 months ago
  • barcode
  • barcode
  • windows
