node-red-contrib-balena-cli 1.1.0
A comprehensive Node-RED wrapper for Balena CLI providing device management, fleet operations, SSH access, and variable management for IoT deployments
npm install node-red-contrib-balena-cli
Version Authentication Nodes
A comprehensive Node-RED wrapper for the Balena CLI, providing powerful IoT device and fleet management capabilities directly within Node-RED flows.
Overview
This Node-RED contribution package provides six specialized nodes that wrap the Balena CLI, enabling seamless integration of Balena IoT operations into Node-RED automation workflows:
  • balena-config: Configuration node for authentication and connection management
  • balena-device: Device management and control
  • balena-fleet: Fleet lifecycle and configuration management
  • balena-ssh: SSH access and command execution on devices
  • balena-variables: Environment variable management for fleets and devices
  • balena-deploy: Code deployment and release management
  • balena-supervisor: Local supervisor operations for nodes running on balena devices
Authentication
Balena Configuration Node
The balena-config node provides centralized authentication management for all Balena operations. It supports three login methods:
  1. Email & Password - Traditional login with Balena account credentials
  2. API Token - Token-based authentication (recommended for production)
  3. Browser Login - Interactive browser-based login (development only)
Getting API Tokens
For production deployments, API tokens are recommended:
  1. Login to the Balena Dashboard
  2. Go to Preferences → Access Tokens
  3. Click "Create API Token"
  4. Give it a name and copy the token
  5. Use the token in your balena-config node
openBalena Support
For openBalena instances, simply change the API URL in the config node to match your deployment (e.g., https://api.openbalena.local).
Security Features
  • Credentials are encrypted and stored securely by Node-RED
  • Automatic authentication and session management
  • Support for custom Balena API endpoints
  • Configurable auto-login behavior
🚀 Device Management
  • List and filter devices by fleet
  • Get detailed device information
  • Enable/disable local development mode
  • Restart, shutdown, and control device power states
  • Retrieve device logs with filtering options
  • Move devices between fleets
  • Rename and tag devices
🏗️ Fleet Operations
  • Create, delete, and rename fleets
  • List fleets with organization filtering
  • Manage releases and deployment strategies
  • Pin specific releases or track latest
  • Generate fleet configurations
  • Fleet-wide restart and purge operations
  • Tag management for fleet organization
🔧 SSH & Remote Access
  • Execute commands on devices via SSH
  • Access specific containers/services
  • Create SSH tunnels for port forwarding
  • Host OS command execution
  • Interactive session connection info
  • File transfer capabilities (placeholder)
⚙️ Variable Management
  • Set, get, and remove environment variables
  • Support for both fleet-level and device-level variables
  • Configuration variable management
  • Batch operations for multiple variables
  • Variable renaming and bulk operations
📦 Deployment & Build
  • Push code to fleets with automatic building
  • Local builds without deployment
  • Deploy pre-built Docker images
  • OS image preloading and configuration
  • Release finalization and invalidation
  • Device fleet joining/leaving operations
🎯 Advanced Features
  • Intelligent Caching - Configurable caching for read operations
  • Real-time Status Updates - Visual feedback during long operations
  • Flexible Configuration - Override settings via message properties
  • Error Handling - Comprehensive error reporting and recovery
  • Timeout Management - Configurable timeouts for all operations
  • Output Formats - JSON and text output options
Prerequisites
  1. Balena CLI - Install the Balena CLI and ensure it's in your system PATH:
    npm install -g balena-cli
  2. Balena Account - You'll need either:
    • A Balena Cloud account (free at balena.io)
    • Access to an openBalena instance
    • An API token for authentication
  3. Node-RED - Ensure Node-RED is installed and running
Note: You no longer need to manually login to the Balena CLI as authentication is handled automatically by the balena-config node.
Install the Package
Via Node-RED Palette Manager
  1. Open Node-RED in your browser
  2. Go to the hamburger menu → Manage Palette
  3. Click the "Install" tab
  4. Search for node-red-contrib-balena-cli
  5. Click "Install"
Via npm
Manual Installation
git clone https://github.com/MadnessEngineering/node-red-contrib-balena-cli.git
cd node-red-contrib-balena-cli
npm install
npm link
npm link node-red-contrib-balena-cli
Quick Start
1. Setup Authentication
First, create a balena-config node:
  1. Drag a balena-config node to your flow
  2. Double-click to configure it
  3. Choose your login method (Email/Password, API Token, or Browser)
  4. Enter your credentials
  5. Test the connection
  6. Deploy the configuration
2. Basic Device Listing
  "operation": "list",
  "fleet": "my-iot-fleet"
3. SSH Command Execution
  "operation": "command",
  "deviceUuid": "1234567890abcdef",
  "command": "df -h"
4. Environment Variable Management
  "operation": "set",
  "scope": "fleet",
  "target": "my-iot-fleet",
  "variableName": "API_URL",
  "variableValue": "https://api.example.com"
Note: balena-variables and balena-deploy nodes will be updated with authentication integration in v1.2.0. For now, ensure you're logged in via the CLI manually when using these nodes.
5. Code Deployment
  "operation": "push",
  "fleetName": "my-iot-fleet",
  "sourceDirectory": "/path/to/code",
  "nocache": true
📚 Examples & Templates
The package includes comprehensive example flows to help you get started quickly:
Ready-to-Use Examples
  • examples/basic-device-monitoring.json - Device health monitoring and alerting
  • examples/fleet-management.json - Fleet operations and release management
  • examples/ssh-remote-diagnostics.json - Remote device diagnostics and troubleshooting
  • examples/cicd-deployment-pipeline.json - Complete CI/CD pipeline with rollback
How to Import Examples
  1. Open Node-RED → Menu → Import
  2. Select "choose file" and browse to the examples/ directory
  3. Choose an example JSON file
  4. Configure with your API tokens and device/fleet details
  5. Deploy and test!
For detailed setup instructions and customization tips, see examples/README.md.
Node Documentation
balena-device
Category: balena Color: #00AEEF (Balena Blue) Icon: fa-microchip
Manages Balena devices with operations including listing, information retrieval, power control, log access, and fleet management.
Operations:
  • list - List devices (optionally filtered by fleet)
  • info - Get device details
  • enable_local_mode / disable_local_mode - Development mode control
  • restart / shutdown - Power management
  • logs - Retrieve device logs
  • move - Transfer device between fleets
  • rename - Change device name
  • blink - Blink device LED for identification
  • ping - Check device connectivity status
balena-fleet
Category: balena Color: #4CAF50 (Green) Icon: fa-ship
Comprehensive fleet management including creation, configuration, release management, and device operations.
Operations:
  • list / info - Fleet discovery and details
  • create / delete - Fleet lifecycle
  • rename - Fleet naming
  • releases - Release listing
  • pin_release / track_latest - Release strategy
  • config - Configuration generation
  • restart / purge - Fleet-wide operations
  • devices - Fleet device listing
  • tags / set_tag / remove_tag - Tag management
balena-ssh
Category: balena Color: #FFA500 (Orange) Icon: fa-terminal
Provides SSH access to Balena devices for command execution, tunneling, and file operations.
Operations:
  • command - Execute commands on devices
  • interactive - Get connection info for manual SSH
  • tunnel - Create SSH port forwarding
  • file_transfer - File upload/download (placeholder)
  • host_os - Host OS command execution
balena-variables
Category: balena Color: #9C27B0 (Purple) Icon: fa-cog
Manages environment and configuration variables at both fleet and device levels.
Operations:
  • list / get - Variable retrieval
  • set / remove - Variable management
  • rename - Variable renaming
  • config_vars / set_config_var - Configuration variables
  • batch_set / bulk_remove - Bulk operations
balena-deploy
Category: balena Color: #FF5722 (Deep Orange) Icon: fa-rocket
Handles code deployment, building, and release management for Balena applications.
Operations:
  • push - Build and deploy code
  • build - Local build without deployment
  • deploy - Deploy pre-built images
  • preload - OS image preloading
  • release_finalize / release_invalidate - Release management
  • join / leave - Device fleet management
  • os_configure / local_configure - OS and device configuration
balena-supervisor
Category: balena Color: #8cc8ff (Light Blue) Icon: balena.png
Manages local supervisor operations for nodes running ON balena devices (not remote management).
Operations:
  • ping - Check supervisor connectivity
  • device - Get device state information
  • restart - Restart a specific service/container
  • reboot - Reboot the entire device
  • shutdown - Shutdown the device
  • purge - Purge application data
  • update - Trigger application update
  • lock - Lock updates
  • unlock - Unlock updates
  • apps - Get application state
  • logs - Get supervisor logs
Requirements:
  • Must be running on a balena device
  • Requires BALENA_SUPERVISOR_ADDRESS and BALENA_SUPERVISOR_API_KEY environment variables
Configuration Options
Common Settings
  • Name - Node display name
  • Operation - Primary operation to perform
  • Timeout - Command execution timeout (milliseconds)
  • Output Format - JSON or text output
  • Enable Caching - Cache read operations for performance
  • Cache Duration - How long to cache results (seconds)
Node-Specific Settings
Each node has specific configuration options relevant to its operations:
  • Device nodes require Device UUIDs
  • Fleet nodes require Fleet names and optionally Device types
  • SSH nodes require connection parameters
  • Variable nodes require scope (fleet/device) and target
  • Deploy nodes require source directories and build options
Message Properties
All nodes support configuration override via message properties. Common properties include:
msg = {
  operation: "list",           // Override configured operation
  timeout: 60000,             // Override timeout
  cached: false,              // Force fresh execution
  // Node-specific properties...
  deviceUuid: "...",          // For device operations
  fleetName: "...",           // For fleet operations
  command: "...",             // For SSH operations
  variableName: "...",        // For variable operations
  sourceDirectory: "..."      // For deployment operations
Examples
Fleet Device Monitoring
Create a flow that monitors all devices in a fleet and alerts on offline devices:
  1. Inject node → triggers every 5 minutes
  2. balena-device → list operation with fleet filter
  3. Function node → filter offline devices
  4. Switch node → route if any offline devices found
  5. Notification → send alert
Automated Deployment Pipeline
Create a CI/CD pipeline that deploys code when changes are detected:
  1. File Watch → monitors code directory
  2. balena-deploy → push operation with nocache option
  3. balena-device → restart all devices in fleet
  4. Notification → deployment success/failure alert
Environment Configuration Management
Manage environment variables across fleets:
  1. HTTP In → receives configuration updates
  2. Function node → processes configuration changes
  3. balena-variables → batch_set operation
  4. balena-fleet → restart to apply changes
  5. HTTP Response → confirm completion
Remote Device Diagnostics
SSH into devices to run diagnostic commands:
  1. Dashboard Input → select device and command
  2. balena-ssh → command operation
  3. Function node → format output
  4. Dashboard Output → display results
Error Handling
All nodes provide comprehensive error handling:
  • CLI Errors - Balena CLI command failures
  • Authentication - Invalid or expired credentials
  • Network Issues - Connectivity problems
  • Timeout Errors - Operation timeouts
  • Validation - Invalid parameters or missing requirements
Error information is available in:
  • Node status indicators
  • msg.error property
  • Node-RED debug panel
  • Console logs
Performance & Caching
Caching Strategy
  • Read operations (list, info, logs) are cached by default
  • Write operations always execute fresh
  • Cache keys include operation and parameters
  • Configurable cache duration per node
Timeout Management
  • Default timeouts are optimized per operation type
  • Build operations: 30 minutes
  • Standard operations: 30 seconds
  • SSH operations: 30 seconds
  • Configurable per node instance
Resource Usage
  • Minimal memory footprint with optional caching
  • Efficient CLI command execution
  • Concurrent operation support
  • Background process management for long operations
Troubleshooting
Common Issues
"balena command not found"
  • Ensure Balena CLI is installed and in PATH
  • Verify installation: which balena
"Authentication failed"
  • Login to Balena: balena login
  • Check authentication: balena whoami
"Device not found"
  • Verify device UUID is correct
  • Ensure device is online and accessible
  • Check fleet permissions
"SSH connection failed"
  • Verify device is online
  • Ensure SSH is enabled on device
  • Check network connectivity
Debug Mode
Enable debug logging by setting the environment variable:
DEBUG=node-red-contrib-balena-cli:* node-red
Contributing
We welcome contributions! Please see our Contributing Guidelines for details.
Development Setup
  1. Clone the repository
  2. Install dependencies: npm install
  3. Link for development: npm link
  4. Run tests: npm test
Reporting Issues
Please report issues on our GitHub Issues page with:
  • Node-RED version
  • Balena CLI version
  • Operating system
  • Detailed error messages
  • Steps to reproduce
Support
Acknowledgments
Made with ❤️ by the MadnessEngineering team
Version: 1.1.0
Updated 1 year, 6 months ago
56 in the last week
  • balena-config
  • balena-device
  • balena-fleet
  • balena-ssh
  • balena-supervisor
  • balena
  • iot
  • device-management
  • fleet-management
  • ssh
  • cli
  • container
  • deployment
  • edge-computing
  • docker
  • embedded
  • remote-access
  • variables
  • configuration
  • madness
  • interactive
