node-red-contrib-backblaze-b2 1.0.11
A Node-RED node to watch, save and retreive files from an Backblaze B2 bucket
npm install node-red-contrib-backblaze-b2
Node-Red B2 Backblaze Library
This Node-Red library allows users to interact with the B2 Backblaze cloud storage service. The library contains four nodes: list, download, upload, and delete. These nodes provide users with the ability to perform common operations such as uploading, downloading, and deleting files from their B2 Backblaze account.
Once the Node-Red B2 Backblaze library is installed, you can use it to interact with your B2 Backblaze account. Below is a brief overview of each node and its functionality. more specific documentation can be found in the Help section in node-red itself.
List Node
The list node allows you to retrieve a list of files from your B2 Backblaze account. You can specify a bucket name and a file prefix to filter the results. The output of this node is an array of filenames, where each object represents a file in your B2 Backblaze account.
Download Node
The download node allows you to download a file from your B2 Backblaze account. You can specify a bucket name and a file name to retrieve the file. The output of this node can also be specified. This library supports all the options that the backblaze-b2 library also supports. Those options are arraybuffer, blob, document, json, text, stream.
Upload Node
The upload node allows you to upload a file to your B2 Backblaze account. You can specify a bucket name, a file name, and the contents of the file. This node always expects msg.payload to be a buffer. The output of this node is an object containing information about the uploaded file.
Delete Node
The delete node allows you to delete a file from your B2 Backblaze account. You can specify a bucket name and a file name to delete the file. The output of this node is an object containing information about the deleted file.
Dependencies
This library depends on the following Node.js modules:
  • backblaze-b2: A Node.js library for interacting with the B2 Backblaze cloud storage service.
This library is released under the MIT License.
Version: 1.0.11
Updated 2 years, 7 months ago
2 in the last week
  • backblaze-config-b2
  • Backblaze b2 list
  • Backblaze b2 download
  • Backblaze b2 delete
  • Backblaze b2 upload
  • backblaze
  • b2
