node-red-contrib-azure-iothub-service 0.0.3
Nodes to communicate with devices via Azure IoT Hub and Event Hubs.
npm install node-red-contrib-azure-iothub-service
alt text
npm install -g node-red-contrib-azure-iothub-service
eventhub-recv
Receive messages sent from devices via the builtin Event Hub.
iothub-send
Send cloud2device messages to your IoT Hub devices.
iothub-registry
Manage IoT Hub Devices.
List devices:
method: "device"
Get device:
method: "device", deviceId: str
Create device:
method: "device.create", deviceId: str
payload (optional):
{ status: 'enabled', authentication: { x509Thumbprint: { primaryThumbprint: XXX, secondaryThumbprint: XXX } } }
Get twin:
method: "twin", deviceId: str
Update twin:
method: "twin.update", deviceId: str
payload:
{ tags: { city: "Redmond" }, properties: { desired: { telemetryInterval: 1000 }, } }
Delete device:
method: "device.delete", deviceId: str
List configurations:
method: "config"
Create configuration:
method: "config.create"
payload:
{ id: 'chiller4000x', content: { deviceContent: { 'properties.desired.chiller-water': { temperature: 66, pressure: 28 } } }, metrics: { queries: { waterSettingsPending: "SELECT deviceId FROM devices WHERE properties.reported.chillerWaterSettings.status='pending'" } }, targetCondition: "properties.reported.chillerProperties.model='4000x'", priority: 20 }
Get configuration:
method: "config", configId: str
Update configuration:
method: "config.update", configId: str
payload:
{ content: { deviceContent: { 'properties.desired.chiller-water': { pressure: 29 } } } }
Delete configuration:
method: "config.delete", configId: str
other functionality
lower-priority
even lower priority
Version: 0.0.3
Updated 2 years, 6 months ago
4 in the last week
  • eventhub-recv
  • iothub-registry
  • iothub-send
  • Azure
  • Azure Event Hub
  • Event Hub
  • IoT
  • Event Hubs
