node-red-contrib-axis-host 1.6.5
Axis Devices resource binding nodes that provides access to events, image capture and analytics data. Node-RED must be running on the Axis Device.
npm install node-red-contrib-axis-host
When running Node-RED on an Axis Device, these nodes provides bindings to resources in the device.
Events
Revice events detected in the Axis device.
Camera
Capture a JPEG image from the Axis camera with user defined resolutions. It is also possible to get a cropped part of the image.
Trigger
Generate an event in the Axis device that can be used to trigger an action in the device or a VMS (Video Management System). Three events are avaialbel. Event (value), State (true/false), and Data (Arbitrary string e.g. JSON)
Objects
Analytics data of objects detected by the camera including bounding box and classification. The output can be configured to recive detections, tracker, or paths.
Change log
1.6.0
  • Adjustmens for changes in Node-RED version 4.2.0 (Axis OS 12)
1.5.3
  • Fixed faulty coordinates in Object Paths in the Axis Objects Node
  • Updated Axis Host examples
1.5.0
  • Updated for Node-RED-Installer ACAP version 4.5.0. Do not install/upgrade unless you run version 4.5.0.
1.4.1
  • Added support for radar including examples.
1.3.8
  • Updated examples
1.3.7
  • Fixed flaw in Object Detections Example
1.3.6
  • Updated examples
1.3.5
  • Fixed flaws in examples
1.3.4
  • Updated examples
1.3.3
  • Updated example Object Detection example
1.3.2
  • Fixed a flaw in Object Path example
1.3.1
  • Added examples for Object Detection, Tracker and Path
1.3.0
  • Fixed bugs in image capture
1.1.7
  • Added support for Objects attribute: color, bag, hat, face
Version: 1.6.5
Updated 1 year ago
333 in the last week
  • Events
  • Camera
  • Trigger
  • Objects
  • Axis
