node-red-contrib-axis-com 1.8.3
Simplified integration with Axis devices
npm install node-red-contrib-axis-com
Nodes to simplify integration with Axis devices. See examples.
Buy Me A Coffee
This node replaces the following nodes that are deprecated
  • node-red-contrib-device
  • node-red-contrib-acap
  • node-red-contrib-security
Device Node
Common device management actions.
  • Device info
  • Connections
  • Syslog
  • Set name
  • Set time
  • Set location
  • Restart
  • Upgrade firmware
  • VAPIX GET
  • VAPIX POST
  • SOAP POST
Camera Node
Common camera actions
  • JPEG image
  • Camera info
  • Get/Set image settings
  • List recordings (SD Card and NAS)
  • Start/Stop recording
  • Set video filter
ACAP Node
Common ACAP actions
  • List ACAP and status
  • Start/Stop/Remove ACAP
  • Install ACAP
Security Node
Common device security controls actions
  • List device accounts
  • Set/Update/Remove account
  • Enable/disable discovery protocols
  • Enable/Disable SSH
  • Set SSH user
  • Set Firewall (IP Tables)
  • List certificates
  • Generate CSR
  • Install certificate
  • Set HTTPS (certificte)
History
1.8.3
  • Improved exceptionhandling when invalid network address is used
  • Allow any account name (beside root) to be added/intialized on a factory default device
1.8.2
  • Fixed flaw device firmware upgrade
1.8.1
  • Fixed flaw introduced in 1.8.0
1.8.0
  • Refactoring exception handling. Trown errors are now more consistant and informative.
  • Device request that responds with JSON will now throw an error on 200 OK if the JSON has a property "error"
1.7.0
  • Fixed and updated file upload functions for ACAP and Camera overlay image.
1.6.1
  • In Axis Camera, reintroduced overlay update.
1.6.0
  • In Axis Device, reintroduced firmware upgrade in from a local file as that approach is much more efficient that providing dile buffer data.
1.5.0
  • Bug fixes
1.4.2
  • Fixed node recording | stopped
1.4.1
  • Fixed a clumsy flaw that broke Device Node when updating to 1.4.0
1.4.0
  • Added support for HTTP Patch in the Device node
  • Fixed aa faulty error response on Camera SD Card Stop Recording when the operation was actually successful.
  • Removed the resolution selection in Camera SD Cardt Start recording as it had no impact.
1.3.0
  • Added support to set SSH user introduced in firmware 11.5.x
  • Added support for HTTP Put in Device node
1.2.3
  • Fixed flaw caused error when upgrading firmware
1.2.2
  • Fixed flaw that prevented reading the DeviceInfo from devices with older firmware
1.2.1
  • Ability to get device info without authentication. If authetication fails, basic device info is provided withot an error is thrown.
  • Minor fixes
1.1.5
  • Extended device info with support for more Axis models
1.1.4
  • Fixed faulty links in package.json
1.1.3
  • Fixed a flaw listing certificates when device responds with >= 400 error code
1.0.3
First commit
Version: 1.8.3
Updated 2 years, 9 months ago
Rating: 3.0 2
24 in the last week
  • Device Access
  • Axis device
  • Axis camera
  • Axis ACAP
  • Axis Security
  • Axis
  • Camera
