node-red-contrib-awtrix-epl-live 0.7.5
awtrix live football
npm install node-red-contrib-awtrix-epl-live
EPL Match Tracker
Basic Usage
Basic usage example
Dependencies
Pre-load any icons to your Awtrix display(s).
Double-click the node and set:
  • Country Select a country to decide which league and cups competitions to follow:
    Country Leagues Cups
    England Premier League, Championship FA Cup, Carabao Cup, Community Shield
    Scotland Premiership, Championship Scottish Cup, League Cup
    Germany Bundesliga, 2. Bundesliga DFB-Pokal, DFL-Supercup
    Spain LaLiga, LaLiga 2 Copa del Rey, Supercopa de Espana
    Italy Serie A, Serie B Coppa Italia, Supercoppa Italiana
    France Ligue 1, Ligue 2 Coupe de France, Trophee des Champions
    Portugal Liga Portugal Taca de Portugal, Primeira Liga Playoff
  • Tracked teams A JSON array of team names (case-insensitive).
  ["Liverpool", "Manchester City", "Crystal Palace", "Aston Villa"]
  ["Bayern Munich", "Borussia Dortmund", "Eintracht Frankfurt", "Werder Bremen"]
Team names have been relaxed and more common names are also accepted
  ["lfc", "man city", "palace", "villa"]
  ["bayern", "bvb", "frankfurt", "werder"]
A name that can't be found shows Unable to validate.
  • National teams A JSON array of national team names, the same format as Tracked teams. Leave it empty to switch internationals off. Native names are accepted:
  ["England", "Deutschland", "EspaƱa"]
Tracks the UEFA Nations League, the European Championship and Euro qualifiers.
  • Additional competitions
    True / False in the dialog options will include or exclude team tracking for UEFA competitions.
    • Champions League.
    • Europa League.
    • Europa Conference League.
  • Language - the language used for AWTRIX messages. Default follows the selected country.
  • Goals icon - icon ID used for goal, penalty goal, own goal, and disallowed goal notifications. 0 (default) no icon.
  • Red card icon - icon ID used for red card notifications. 0 (default) no icon.
  • Full time icon - icon ID used for full time notifications. 0 (default) no icon.
  • Recommended LaMetric Icon Numbers
    Icon ID Used for
    2965 goal / penalty goal / own goal, disallowed goal & full time
    43844 red card
  • Minimum brightness
    Your Awtrix device brightness has a direct effect on how readable certain text colours appear and darker palette colours can be difficult to view on the display.
    The minimum brightness dialogue setting is a 'perceived colour' brightness value used to determine if a team colour will be readable on your Awtrix display.
    All team name colours are evaluated against this value, if they fall below this threshold they fail the test. Primary and alternate colours are tested in order before falling back to '#FFFFFF'.
    The default value for this setting is 30. If you are finding dark text colours difficult to read, increase this number.
Outputs
This node has three outputs, wire your own downstream nodes to these
Output pin #1 - Payload event type, wire to anything you want (eg. Alexa/Google notification)
msg.payload is one of: "goal", "disallowed goal", "red card", or "full time". Penalties and own goals are also reported as "goal" on this output. The distinction between goal events is only reported by pin #2 & pin #3.
Wire a switch node off this output to route each event type to your own desired trigger.
Here is an Alexa Ready audio clip you can use for "GOAL" events to get you started
"<audio src='https://nr-alexa-sounds.s3.eu-west-2.amazonaws.com/goal.mp3'/>"
Output pin #2 - AWTRIX 3 payload
msg.payload is a ready-to-send 2 part AWTRIX 3 notification object set to fire with pin #1 and carries the event plus a followup detail (incl. score, player, team names). Wire this pin straight to one or more mqtt out nodes pointed at your AWTRIX 3 device(s).
Output pin #3 - AWTRIX NG payload
msg.payload The same as pin #2 but formatted for AWTRIX-NG devices.
internally
  • Tracked team colours
    Primary & secondary team colours are assessed independently.
    Home team first to determine if the primary colour is deemed too dark or not viable for AWTRIX (see Minimum brightness).
    Away team colours are assessed in the same manner and checked against the home team resolved colour to avoid the two clashing.
  • Node Status
    The node will show any upcoming matches for tracked teams only:
    • "populating matches" - shown after a deploy while match data loads.
    • "nothing upcoming" - none of your tracked teams have any immediate matches.
    • "next match xxxx-xx-xx" - date of the next match from your tracked teams list.
    • "kick off shortly" - a match is about to begin.
    • "live - in play" - match underway and actively polling for live data.
Version: 0.7.5
Updated 1 month ago
110 in the last week
  • awtrix
  • football
  • soccer
  • epl
  • premier league
  • bundesliga
  • la liga
  • serie a
  • uefa
  • fifa
