node-red-contrib-aws-sqs-variable 1.0.1
Node-RED nodes for AWS SQS send/receive with flexible credentials
npm install node-red-contrib-aws-sqs-variable
A production-ready Node-RED node for AWS SQS operations that sends and receives messages with flexible credential handling.
  • ๐Ÿ“ฌ Send messages to AWS SQS
  • ๐Ÿ“ฅ Receive messages from AWS SQS
  • ๐Ÿ—๏ธ Flexible credential configuration (IAM roles, direct credentials, context variables)
  • ๐ŸŽฏ TypedInput support for dynamic Queue URL and payload
  • ๐Ÿ”„ FIFO support with Message Group and Deduplication IDs
  • ๐Ÿงพ Optional JSON parsing for received messages
  • โฑ๏ธ Built-in polling mode with status indicator
  • ๐Ÿ›ก๏ธ Production-ready with comprehensive error handling
After installation, restart Node-RED to load the new nodes.
AWS Configuration Node
The module uses a configuration node that supports multiple authentication methods:
IAM Role Authentication (Recommended)
  • โœ… Use when running on EC2 instances with IAM roles
  • โœ… No credentials needed in Node-RED
  • โœ… Automatic credential rotation
Access Key Authentication
Supports multiple credential sources:
  • String: Stored securely in Node-RED credentials (encrypted)
  • Flow Context: Retrieved from flow context variables
  • Global Context: Retrieved from global context variables
  • Environment Variables: Retrieved from environment variables
Basic Usage
  1. Create AWS Configuration
    • Add an "aws-sqs-config" node
    • Configure your AWS region and credentials
  2. Add AWS SQS Node
    • Drag "aws-sqs" node to your flow
    • Select your AWS configuration
    • Choose operation: Send or Receive
Send Messages
Configure:
  • Queue URL (string, msg, flow, global, env)
  • Message Body (string, msg, flow, global, env)
Optional for FIFO:
  • Message Group ID (required for FIFO)
  • Deduplication ID (optional if content-based deduplication is enabled)
Receive Messages
Configure:
  • Queue URL
  • Max Messages (1-10)
  • Wait Time (s) (0-20, long polling)
  • Visibility Timeout (s)
  • Delete After Receive
  • Parse JSON Body (optional)
Polling:
  • Enable Polling to receive messages on a schedule
  • Set Poll Interval (s)
Input
Message Properties
  • msg.queueUrl (optional): Queue URL if not configured in node
  • msg.messageGroupId (optional): FIFO Message Group ID
  • msg.messageDeduplicationId (optional): FIFO Deduplication ID
Example Input
msg = {
  queueUrl: "https://sqs.eu-central-1.amazonaws.com/123456789012/my-queue",
  payload: { message: "Hello!" }
Output
Send Success Response
msg = {
  payload: {
    messageId: "abcd-1234",
    md5OfMessageBody: "e99a18c428cb38d5f260853678922e03"
Receive Success Response
msg = {
  payload: [
      MessageId: "...",
      ReceiptHandle: "...",
      Body: "raw string or parsed JSON when enabled"
Error Response
msg = {
  payload: {
    error: "Error message"
FIFO Notes
  • Message Group ID is required for FIFO queues
  • Deduplication ID must be unique within a 5-minute window
  • Ordering is guaranteed only within the same Message Group
Security Best Practices
  • โœ… Use IAM roles when possible (recommended for EC2 instances)
  • โœ… Store credentials in context variables rather than hardcoding
  • โœ… Use environment variables for sensitive configuration
  • โœ… Rotate access keys regularly
  • โœ… Follow the principle of least privilege
  • โœ… Enable AWS CloudTrail for audit logging
Error Handling
The node provides comprehensive error handling:
  • Configuration errors: Missing or invalid AWS configuration
  • Authentication errors: Invalid credentials or permissions
  • Queue errors: Invalid Queue URL or insufficient permissions
  • Network errors: Connection issues with AWS
All errors are logged and sent in the message payload for downstream processing.
Requirements
  • Node.js >= 12.0.0
  • Node-RED >= 2.0.0
  • AWS account with SQS access
  • Appropriate IAM permissions
MIT
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
Support
If you encounter any issues or have questions, please open an issue in the project repository.
Version: 1.0.1
Updated 10 months ago
72 in the last week
  • aws-sqs-config
  • aws-sqs
  • aws
  • sqs
  • aws-sqs
  • queue
  • fifo
  • message-queue
  • messaging
