node-red-contrib-aws-s3-pro 1.0.16
A Node-RED node for Amazon S3 operations with production-grade connection pooling. Supports all S3 operations via AWS SDK v3.
npm install node-red-contrib-aws-s3-pro
Key Features:
  • ✅ Connection Pooling - Shared connections across all nodes for optimal performance
  • ✅ AWS SDK v3 - Latest AWS SDK with modern architecture
  • ✅ All S3 Operations - Support for 100+ S3 API operations
  • ✅ Automatic Connection Management - TTL-based refresh and cleanup
  • ✅ HTTP Keep-Alive - Reuses TCP connections for better performance
Configuration Node (aws-s3-config)
Configure your AWS credentials and connection settings. Supports:
  • Access Key ID and Secret Access Key (from string, msg, flow, global, or env)
  • IAM Role authentication (recommended for EC2/ECS/Lambda)
  • Custom endpoints (for S3-compatible services)
  • Region configuration
Note: All nodes using the same configuration share the same connection pool automatically.
Amazon S3 Node (aws-s3) - Generic API Node
A generic node that supports all S3 operations using AWS SDK v3. This node provides access to the complete S3 API including bucket management, object operations, multipart uploads, and advanced features.
Features:
  • ✅ Supports all 100+ S3 operations (ListBuckets, GetObject, PutObject, DeleteObject, etc.)
  • ✅ Connection pooling - Automatically shares connections with other nodes
  • ✅ Parameters provided via message object (msg.Bucket, msg.Key, etc.)
  • ✅ Automatic JSON parsing for complex objects
  • ✅ Special handling for GetObject streaming (returns buffer in msg.payload)
  • ✅ Dual output: success (first output) and error (second output)
Usage Examples:
ListBuckets - List all buckets:
No parameters needed
ListObjects - List objects in a bucket:
msg.Bucket = "my-bucket"
// Optional: msg.Prefix = "folder/"
GetObject - Download a file:
msg.Key = "path/to/file.txt"
// Result: msg.payload contains the file content as buffer
//         msg.s3Metadata contains file metadata
PutObject - Upload a file:
msg.payload = "file content" // or Buffer
// Optional: msg.ContentType = "text/plain"
DeleteObject - Delete a file:
CopyObject - Copy a file:
msg.Bucket = "destination-bucket"
msg.CopySource = "source-bucket/source-key"
msg.Key = "destination-key"
For complex parameters, provide JSON strings in the message - they will be automatically parsed.
Connection Pooling
How it works:
  • All nodes using the same AWS configuration share a single connection pool
  • Connections are automatically reused across multiple requests
  • Connections refresh after 30 minutes (TTL) to ensure freshness
  • Automatic cleanup of expired connections every 5 minutes
  • HTTP keep-alive enabled for optimal TCP connection reuse
Benefits:
  • Reduced connection overhead
  • Better performance for high-frequency operations
  • Lower memory usage
  • Automatic connection lifecycle management
Example: If you have 10 aws-s3 nodes using the same aws-s3-config, they all share the same connection pool automatically.
Version: 1.0.16
Updated 11 months, 2 weeks ago
  • aws-s3-config
  • aws-s3
  • node-red-contrib
  • aws
  • aws-s3
  • s3
  • s3-pool
  • connection-pool
