node-red-contrib-aws-qldb 0.1.2
AWS Quantum Ledger Database (QLDB) Nodes
npm install node-red-contrib-aws-qldb
AWS Quantum DB Ledger Nodes for Node-Red
This was forked from Node-RED Node TypeScript Starter
AWS QLDB nodes for node-red. Currently only insert-rows is implemented as a proof-of-concept.
Example Use Cases
  • Write only insertions to AWS QLDB (audit logs, metadata hashing, etc.)
Using (with node-red)
Install via CLI (or use the pallette manager and search for node-red-contrib-aws-qldb)
npm i node-red-contrib-aws-qldb
Inputs / Outputs
Insert Node
The insert node will take whatever is on msg.payload and attempt to insert it into the AWS QLDB you have defined. It will accept a plain object or an array of objects.
It will return a list of document IDs if successful.
Getting Started
Everything has been tested with node version: v12.18.3
# Install dependencies
npm i
# Might need typescript, maybe
npm i -g tsc typescript
# Run and test
# NOTE: The test involves live data (for now)
#    YOu need to export the following properties
export AWS_ACCESS_KEY_ID="...."
export AWS_SECRET_ACCESS_KEY=="...."
export AWS_REGION="us-east-1"
export AWS_LEDGER="your-ledger-name"
export AWS_TABLE="your-table-name"
npm run dev
Building Node Set
Create a production build:
npm run build
Reference it in your node-red:
# From node-red local directory:
npm i /path/to/this/repo
Local packaging
# Bundle it up
npm run build && npm pack
# -> produces artifact like: node-red-contrib-aws-qldb-0.1.0.tgz
# Copy to node red directory
cp node-red-contrib-aws-qldb-0.1.0.tgz /path/to/node-red/local
cd /path/to/node-red/local
# Install bundle
npm i node-red-contrib-aws-qldb-0.1.0.tgz
TODO
  • Use mocks in tests
  • Uplevel configuration (or reuse regular aws one if possible)
  • Add more nodes
    • Select
    • Update
    • Delete
Submitting Changes
Create a pull request.
MIT © AJ Newton (see ./LICENSE)
Forked Project License
MIT © Alex Kaul (see ./LICENSE.node-red-typescript-starter)
Version: 0.1.2
Updated 4 years, 6 months ago
2 in the last week
  • aws-qldb-insert-rows
  • nodered
  • aws
  • qldb
  • quantum
  • ledger
  • database
  • db
