node-red-contrib-aws-kms 2.0.2
Node-RED node for AWS KMS operations with flexible credential handling
npm install node-red-contrib-aws-kms
A Node-RED node for AWS KMS (Key Management Service) operations. This module provides a simple way to perform encryption, decryption, and key generation operations using AWS KMS directly from your Node-RED flows.
Developed by Andrii Lototskyi
After installation, restart Node-RED to load the new nodes.
This node provides the following AWS KMS operations:
  • Encrypt: Encrypt data using a KMS key
  • Decrypt: Decrypt data that was encrypted using KMS
  • Generate Data Key: Generate a new data key for client-side encryption
Supported Operations
  1. Encrypt
    • Encrypts data using the specified KMS key
    • Input: String or Buffer in msg.payload
    • Output: Base64-encoded encrypted data in msg.payload
  2. Decrypt
    • Decrypts data encrypted using KMS
    • Input: Base64-encoded encrypted data in msg.payload
    • Output: Decrypted data in msg.payload
  3. Generate Data Key
    • Generates a new data key for client-side encryption
    • No input required
    • Output: Object in msg.payload containing:
      • plaintext: Base64-encoded plaintext key
      • ciphertext: Base64-encoded encrypted key
AWS Credentials
  1. Add a new AWS KMS Config node
  2. Choose an authentication method:
    • IAM Role (recommended for EC2 instances)
    • Access Key and Secret Key
    • Temporary credentials with Session Token
Node Configuration
  1. Add an AWS KMS node to your flow
  2. Configure the node with:
    • AWS credentials (select the config node)
    • Region (e.g., us-east-1)
    • Operation type
    • Key ID (ARN of the KMS key)
    • Key Spec (for Generate Data Key operation)
Examples
Basic Encryption Flow
        "id": "aws-kms-encrypt",
        "type": "aws-kms",
        "name": "Encrypt Data",
        "aws": "aws-credentials",
        "region": "us-east-1",
        "operation": "encrypt",
        "keyId": "arn:aws:kms:us-east-1:123456789012:key/your-key-id"
Decryption Flow
        "id": "aws-kms-decrypt",
        "type": "aws-kms",
        "name": "Decrypt Data",
        "operation": "decrypt"
Generate Data Key Flow
        "id": "aws-kms-generate-key",
        "type": "aws-kms",
        "name": "Generate Data Key",
        "operation": "generateDataKey",
        "keyId": "arn:aws:kms:us-east-1:123456789012:key/your-key-id",
        "keySpec": "AES_256"
Best Practices
  1. Security
    • Use IAM roles when possible
    • Rotate access keys regularly
    • Use temporary credentials for enhanced security
    • Follow the principle of the least privilege
  2. Performance
    • Use data keys for large data encryption
    • Cache data keys when possible
    • Consider regional placement of KMS keys
  3. Error Handling
    • Always handle encryption/decryption errors
    • Implement retry logic for transient failures
    • Log security-related events
Troubleshooting
Common Issues
  1. "Key ID required" Error
    • Ensure the Key ID is set in node config or msg.keyId
    • Verify the Key ID format (should be a valid KMS key ARN)
  2. "Could not load credentials" Error
    • Check AWS credentials configuration
    • Verify IAM role permissions
    • Ensure environment variables are set correctly
  3. "Invalid region" Error
    • Verify the region format (e.g., us-east-1)
    • Ensure the region is supported by AWS KMS
  4. "Invalid ciphertext" Error
    • Verify the input data is properly base64 encoded
    • Check if the data was encrypted with the same key
Debugging
  1. Enable Node-RED debug output
  2. Check AWS CloudWatch logs
  3. Verify IAM permissions
  4. Test with AWS CLI first
Contributing
  1. Fork the repository
  2. Create a feature branch
  3. Commit your changes
  4. Push to the branch
  5. Create a Pull Request
MIT
Support
For issues and feature requests, please use the GitHub issue tracker.
Version: 2.0.2
Updated 10 months ago
Rating: 5.0 2
  • aws-kms
  • aws-kms-config
  • aws
  • kms
  • encryption
  • decryption
  • key-management
  • security
  • context
  • credentials
  • iam
