node-red-contrib-aws-iot-custom-auth 0.2.0
An IoT aws-thing with the Custom Authorizer node for Node-RED
npm install node-red-contrib-aws-iot-custom-auth
A Node-Red node to read and write to the Amazon Web Services AWS IoT using the Custom Authorizer.
Support ThingShadow and MQTT protocol with Certificate Store by clientId (thingName) or using Custom Authorizer
Usage with custom authorizer
Use "Custom Authorizer" type for your device and specify:
  • Custom Authorizer Name (optional)
  • Token Key
  • Token Value
  • Custom Authorizer Signature
You don't have to provide certificated in this case.
See more at https://docs.aws.amazon.com/iot/latest/developerguide/custom-auth.html
Usage with certificates
  • Install your AWS certificates into your local folder where node-red can reach your directory
    Example:
	/root/.agent/certs/-
					|--YourThingName.private.key
					|--YourThingName.cert.pem
					|--root-CA.crt
YourThingName is the AWS Thing name what is the value you keyin when creating your thing/device.
  • Setup the node-red-contrib-aws-iot-custom-auth node with AWS Certs path pointed to /root/.agent/certs/
    Example:
	awsCerts = /root/.agent/certs/
  • The final configuration will be used in the node-red-contrib-aws-iot-custom-auth code look likes:
	keyPath : '/root/.agent/certs/YourThingName.private.key',
	certPath : '/root/.agent/certs/YourThingName.cert.pem',
	caPath : '/root/.agent/certs/root-CA.crt',
	clientId : YourThingName,
	host : <YourAWSIoTCustomEndpoint>
See more at https://github.com/aws/aws-iot-device-sdk-js/blob/master/README.md#certificate-configuration
Runtime information
This node was tested to Node.js v7.4.0 and NPM 5.6.0 on Node-Red v0.18.4
Credits
This node is based on iont-node-red-contrib-aws-iot by Darren Chiu.
Version: 0.2.0
Updated 8 years, 10 months ago
3 in the last week
  • aws-iot-device
  • aws-mqtt out
  • aws-mqtt in
  • aws-thing
  • aws-iot
  • aws-thing
  • custom-authorizer
