node-red-contrib-aws-asm 2.0.1
A Node-RED node for AWS Secrets Manager operations
npm install node-red-contrib-aws-asm
A production-ready Node-RED node for AWS Secrets Manager operations that retrieves secrets and stores them in Node-RED context or environment variables.
  • 🔐 Retrieve secrets from AWS Secrets Manager
  • 🏗️ Flexible credential configuration (IAM roles, direct credentials, context variables)
  • 📦 Store secrets in flow context, global context, or environment variables
  • 🔄 Support for both JSON and string secrets
  • 🎯 TypedInput support for dynamic secret IDs
  • ⚡ Real-time credential resolution from context
  • 🛡️ Production-ready with comprehensive error handling
After installation, restart Node-RED to load the new nodes.
AWS Configuration Node
The module uses a configuration node that supports multiple authentication methods:
IAM Role Authentication (Recommended)
  • ✅ Use when running on EC2 instances with IAM roles
  • ✅ No credentials needed in Node-RED
  • ✅ Automatic credential rotation
Access Key Authentication
Supports multiple credential sources:
  • String: Stored securely in Node-RED credentials (encrypted)
  • Flow Context: Retrieved from flow context variables
  • Global Context: Retrieved from global context variables
  • Environment Variables: Retrieved from environment variables
Examples
Environment-based Configuration
// Set environment variables
process.env.AWS_ACCESS_KEY_ID = "your-access-key";
process.env.AWS_SECRET_ACCESS_KEY = "your-secret-key";
// Configure node to use environment variables
Access Key ID: Environment Variable → AWS_ACCESS_KEY_ID
Secret Access Key: Environment Variable → AWS_SECRET_ACCESS_KEY
Mixed Configuration
// Store secret key in global context
global.set("aws_secret", "your-secret-access-key");
// Configure node
Access Key ID: String → stored securely in Node-RED
Secret Access Key: Global Context → aws_secret
Basic Usage
  1. Create AWS Configuration
    • Add an "aws-secret-manager-config" node
    • Configure your AWS region and credentials
  2. Add Secrets Manager Node
    • Drag "aws-secret-manager" node to your flow
    • Select your AWS configuration
    • Configure secret ID and storage options
  3. Configure Secret ID The Secret ID supports multiple input types:
    • String: Direct secret name or ARN
    • Message: From msg.payload.secretId or msg.secretId
    • Flow Context: From flow context variable
    • Global Context: From global context variable
    • Environment Variable: From environment variable
Storage Options
Flow Context
// Store in flow context
storeIn: "flow"
variableName: "dbCredentials"
// Access later
const credentials = flow.get("dbCredentials");
Global Context
// Store in global context
storeIn: "global"
// Access later
const credentials = global.get("dbCredentials");
// For JSON secrets like: {"DB_HOST":"localhost","DB_USER":"admin"}
storeIn: "env"
// Each key becomes an environment variable automatically:
// process.env.DB_HOST = "localhost"
// process.env.DB_USER = "admin"
// No Variable Name needed - each JSON key becomes a separate env var
Output Data
// Send secret directly to output
storeIn: "output"
// msg.payload will contain the secret value
Example Flow
        "id": "inject-node",
        "type": "inject",
        "payload": "{}",
        "wires": [["secrets-node"]]
        "id": "secrets-node",
        "type": "aws-secret-manager",
        "awsConfig": "aws-config",
        "secretId": "my-database-secret",
        "secretIdType": "str",
        "storeIn": "global",
        "variableName": "dbCredentials",
        "wires": [["debug-node"]]
Input
Message Properties
  • msg.secretId (optional): Secret ID if not configured in node
Example Input
msg = {
    secretId: "my-secret-name"
Output
Success Response (when storing in context/env)
msg = {
    payload: {
        status: "Secret stored successfully",
Success Response (when outputting data)
msg = {
    payload: {
        username: "admin",
        password: "secret123",
        host: "database.example.com"
Error Response
msg = {
    payload: {
        error: "Error message"
Security Best Practices
  • ✅ Use IAM roles when possible (recommended for EC2 instances)
  • ✅ Store credentials in context variables rather than hardcoding
  • ✅ Use environment variables for sensitive configuration
  • ✅ Rotate access keys regularly
  • ✅ Follow the principle of least privilege
  • ✅ Enable AWS CloudTrail for audit logging
Error Handling
The node provides comprehensive error handling:
  • Configuration errors: Missing or invalid AWS configuration
  • Authentication errors: Invalid credentials or permissions
  • Secret not found: Invalid secret ID or insufficient permissions
  • Network errors: Connection issues with AWS
All errors are logged and sent in the message payload for downstream processing.
Requirements
  • Node.js >= 12.0.0
  • Node-RED >= 2.0.0
  • AWS account with Secrets Manager access
  • Appropriate IAM permissions
IAM Permissions
Minimum required permissions:
    "Version": "2012-10-17",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "secretsmanager:GetSecretValue"
            "Resource": "arn:aws:secretsmanager:region:account:secret:*"
MIT
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
Support
If you encounter any issues or have questions, please open an issue on GitHub.
Version: 2.0.1
Updated 10 months, 1 week ago
Rating: 5.0 3
12 in the last week
  • aws-secret-manager
  • aws-secret-manager-config
  • aws
  • secrets-manager
  • secrets
  • asm
