node-red-contrib-automation-hat 0.4.4
Node-RED nodes for the Pimoroni Automation HAT, pHAT and HAT Mini
npm install node-red-contrib-automation-hat
Node-RED nodes for Pimoroni Automation HAT/pHAT
Provides nodes
  • Automation HAT:
    • Output Node:
      • Sinking Outputs
      • Relays (1-3 on HAT and 1 only on pHAT)
      • Lights (not on pHAT)
    • Input Node (triggered based on change in input):
      • Buffered Inputs (binary)
      • Analog ADC 1-3 - 12-bit ADC @ 0-25.85V (±2% accuracy)
      • Analog ADC 4 - 12-bit ADC @ 0-3.3V (not on pHAT)
    • Reader Node:
      • On demand reading of input nodes
Unsupported features
  • Other Pins exposed only break out section: SPI, TX (#14), RX (#15), #25 pins
  • Controlling individual indicator lights on each input/output beyond the auto_lights capability.
  • SPI LCD Display on Automation HAT Mini
More Information
More information and examples of using this node can be found in my blog post www.martinrowan.co.uk. Hopefully this will provide some inspiration.
Where to buy
If you find this useful, consider providing some support:
"Buy Me A Coffee"
Dependency - Interfaces
In order to use the capabilities of the HATs you'll need to enable some interfaces: I2C and SPI (for display on Mini HAT), which can be done using sudo raspi-config and enabling the relevant interface types.
Dependency - Node and Node-Red
Details of how to install Node and Node-Red needed for this project on Raspberry Pi can be found here. The script at the top of the page ensures you have the latest supported versions ready for this project.
Dependency - Automation HAT Python Library
First you'll need the Python dependencies for Automation HAT, you can install these with our one-line installer, as per these instructions
curl https://get.pimoroni.com/automationhat | bash
Automation HAT Node-RED
Installation via Node-Red
Run Node-Red and open setting menu, and select Manage palette. Select the install tab, and enter node-red-automation-hat
Install via Node-Red
Installation via NPM
After installing via npm you will need to restart Node-Red
Installation from latest source on GitHub
To install this node you should:
  • Change to your users node-red nodes directory:
    cd ~/.node-red/node_modules
    Note: older node installation may use the location: ~/.node-red/nodes:
  • Clone this repository:
    git clone https://github.com/shortbloke/node-red-contrib-automation-hat
  • Start Node-Red and you should see the new Automation HAT nodes within the Raspberry Pi section.
References
This project is based on the ExplorerHAT node implementation published by Pimoroni.
Troubleshooting
  • [error] Error: FATAL(Unknown Device): Unable to import automationhat python library
    • Ensure you have installed the Pimoroni Automation HAT Python Library
    • Newer installations place the libary into python virtualenv. The default location attempted to be used is: $HOME/.virtualenvs/pimoroni/bin. If you are using a different location either:
      • Create a symlink between then location you have installed the package at the location this Node-Red module expects to use.
      • Update the path by editing $HOME/node-red/node_modules/node-red-contrib-automation-hat/library/automationhatlink and updating the variable VIRTUAL_ENV="$HOME/.virtualenvs/pimoroni/bin"
Version: 0.4.4
Updated 1 year, 9 months ago
10 in the last week
  • rpi-automation-hat in
  • rpi-automation-hat out
  • rpi-automation-hat reader
  • Automation HAT
  • Automation pHAT
  • Automation HAT Mini
  • pimoroni
  • raspberry
  • iot
