node-red-contrib-auth-oidc 1.0.0
Node-RED node to add OpenID Connect authentication to HTTP nodes
npm install node-red-contrib-auth-oidc
Node-RED node to use OpenID Connect with HTTP input nodes.
Screenshot
You have to configure the node by setting the discovery URL of your OpenID Connect provider.
Examples:
Provider Discovery URL
Google https://accounts.google.com/.well-known/openid-configuration
Microsoft https://login.windows.net/common/.well-known/openid-configuration
Salesforce https://login.salesforce.com/.well-known/openid-configuration
Okta https://YOUR_SUB_DOMAIN.okta.com/.well-known/openid-configuration
Auth0 https://YOUR_SUB_DOMAIN.auth0.com/.well-known/openid-configuration
Keycloak https://YOUR_DOMAIN/auth/realms/YOUR_REALM_NAME/.well-known/openid-configuration
This node extract and validate the access token from HTTP headers (Authorization: Bearer XXX).
Decoded token (JWT) is stored into the message property: msg.access_token.
Version: 1.0.0
Updated 2 years, 6 months ago
Rating: 0.0
33 in the last week
  • auth-oidc
  • auth
  • openid
  • oidc
