node-red-contrib-auroral 2.1.10
Nodes for contributing to AURORAL network
npm install node-red-contrib-auroral
Auroral adapter module for NODE-RED
Node-red modules for AURORAL adapter
Developed for AURORAL H2020 project
Disclaimer
Beta version still under testing Extended documentation will follow
There are three nodes:
  • Device
    • represents Auroral device
  • Response
    • for sending requested data back to agent
  • Registrations
    • for retrieving registration from agent
Standard mesage format
Auroral Agent is by default extending messages using mapping, which is generated from Thing description. This ensures sent message will be sent in standart Auroral format. From Node-RED you just need to pass simple value [string, number, object or array], which was choosen during registration (in Thing description)
Development installation
Example flow
Example flow
Example of ThingDescription
  "@context": "https://www.w3.org/2019/wot/td/v1",
  "@type": "Ontology:DeviceType",
  "title": "Sensor1",
  "id": "000-111-222",
  "adapterId": "001-myinfrastructure",
  "description": "Sensor example for the node-red adapter",
  "securityDefinitions": {
    "nosec_sc": {
      "scheme": "nosec"
  "security": "nosec_sc",
  "properties": {
    "temp": {
      "title": "temp",
      "@type": "Ontology:PropertyType",
      "description": "Retrieve temperature of my device",
      "type": "number",
      "forms": [
          "op": [
            "readproperty"
          "href": "http://localhost:1250/api/property/000-111-222/temp"
    "status": {
      "title": "status",
      "description": "Retrieve status of the device",
      "type": "string",
      "forms": [
          "op": [
            "readproperty"
          "href": "http://localhost:1250/api/property/000-111-222/status"
  "actions": {},
  "events": {
    "alert": {
      "title": "alert",
      "description": "Notifications that are pushed to AURORAL from my sensor",
      "forms": [
          "op": [
            "subscribeevent"
          "href": "http://localhost:1250/api/event/000-111-222/alert"
Node-red docs
https://nodered.org/docs/
Known limitations and bugs
  • TD mismatch after depleoying preregistered device ( can be fixed in device properties with get TD from agent button )
  • Changing adapterId after deployment is not allowed
Who do I talk to?
Developed by bAvenir
[email protected] [email protected]
Version: 2.1.10
Updated 3 years, 7 months ago
  • registrations
  • auroralAgent
  • auroralResponse
  • auroralDevice
  • auroral
  • Peter Drahovsky
  • Jorge Almela
