node-red-contrib-atag-one 1.0.1
Atag One thermostat support for node-red
npm install node-red-contrib-atag-one
Description
Nodes facilitating the automation of the Atag One ( https://www.atag-one.com ) with Node-RED ( http://nodered.org ).
$ cd ~/.node-red
$ npm install node-red-contrib-atag-one
- atagone-controller
Configuration node for communication with an Atag One thermostat.
Configuration:
  • Name : Specify a name for the configuration node
  • IP : Specify the ip address
- atagone-get
Gets the status of an Atag One thermostat on an input message.
Configuration:
  • Name : Optionally specify a name
  • Controller : Select the Atag One controller
Messages injected in NodeRED flows (1 channel):
Channel 1: The state of the thermostat:
  • msg.payload.burningHours : Total burning hours
  • msg.payload.roomTemp : The temperature measured by th thermostat
  • msg.payload.outsideTemp : The outside temperature
  • msg.payload.hotWaterTemp : The temperature of the hot water outlet
  • msg.payload.chWaterTemp : The temperature of the heating water
  • msg.payload.chReturnWaterTemp : The temperature of the returned water by the heating infrastructure
  • msg.payload.hotWaterPressure : The pressure for hot water
  • msg.payload.chWaterPressure : The pressure for the heating infrastructure
  • msg.payload.setTemp : The target temperature currently set
Release notes
v1.0.1
  • Added documentation
v1.0.0
  • paletteLabel defined for all nodes
  • Initial implementation
Version: 1.0.1
Updated 8 years, 9 months ago
4 in the last week
  • atagone-controller
  • atagone-get
  • atagone
  • atag-one
