node-red-contrib-array-permutations 0.0.5
Node-red permutations of an array as repeat or messages.
npm install node-red-contrib-array-permutations
node-red function that takes an array then generates permutation sets of specified size of all cells in a loop, generation of cloned messages or an array containing all possible permutations. For loop then message sent to second output on return to input port it sends the next permutation in loop until all have been processed.
Array Permutations
Run the following command in the root directory of your Node-RED install or via GUI install
Test
Folder test contains a flow that tests the various combinations.
Tests
Version
0.0.5 fix bug with perms, added circular, heap, unique, random
0.0.4 fix bug with loop and ensure all separated messages have unique id.
0.0.3 if error set msg.error and send to error port. Fix bug with loop
0.0.1 base
Author
Peter Prib
Version: 0.0.5
Updated 3 years, 5 months ago
License: GPL-3.0
5 in the last week
  • Array Permutations
  • loop
  • permutations
  • heap
  • random
  • combinations
  • circular
  • repeat
  • array
