node-red-contrib-arcgis-rest 1.0.6
Utilizes ArcGIS REST JS to query,delete,update or insert rest data
npm install node-red-contrib-arcgis-rest
On Github node-red-arcgis-rest
On npm node-red-arcgis-rest
This node leverages The ArcGIS Rest js API to return the following functions:
To install use npm,
Use the following link for proper documentation on both ArcGIS Rest js and ArcGIS Rest
ArcGIS Rest API Documentation
ArcGIS Rest Js GitHub
All functions use the msg.arcgis array it is possible to set more values than what is listed but not everything has been tested out
For all options the output returns to the following:
msg.arcgis.response
msg.arcgis.error
msg.arcgis.errorDetails
If the service requires authentication pass the following to:
msg.arcgis.authentication.server (required)
msg.arcgis.authentication.username (required)
msg.arcgis.authentication.password (required)
msg.arcgis.authentication.tokenDuration (required)
Query Features:
queryFeatures
Pass the following to query back features from a rest service
msg.arcgis.queryFeatures.url
msg.arcgis.queryFeatures.where
Update Features:
updateFeatures
Pass the following to update features to a rest service
msg.arcgis.updateFeatures.url (required)
msg.arcgis.updateFeatures.features[0].attributes.ObjectId (required)
msg.arcgis.updateFeatures.features[0].attributes.GlobalID (optional)
msg.arcgis.updateFeatures.features[0].attributes.[COLUMN NAME] (optional)
msg.arcgis.updateFeatures.features[0].geometry.x (optional)
msg.arcgis.updateFeatures.features[0].geometry.y (optional)
msg.arcgis.updateFeatures.features[0].geometry.spatialReference.wkid (required if passing x,y)
Add Features:
addFeatures
Pass the following to add features to a rest service
msg.arcgis.addFeatures.url (required)
msg.arcgis.addFeatures.features[0].attributes.[COLUMN NAME] (optional)
msg.arcgis.addFeatures.features[0].geometry.x (optional)
msg.arcgis.addFeatures.features[0].geometry.y (optional)
msg.arcgis.addFeatures.features[0].geometry.spatialReference.wkid (required if passing x,y)
Delete Features:
deleteFeatures
Pass the following to delete features to a rest service
msg.arcgis.deleteFeatures.url (required)
msg.arcgis.deleteFeatures.objectIds[0] (required)
Get Attachments:
getAttachments
Pass the following to return attachment features from a rest service
msg.arcgis.getAttachments.url (required)
msg.arcgis.getAttachments.featureId (required)
Query Related:
queryRelated
Pass the following to return related records from a rest service
msg.arcgis.queryRelated.url (required)
msg.arcgis.queryRelated.objectIds[0] (required)
Version: 1.0.6
Updated 4 years, 7 months ago
1 in the last week
  • ArcGIS-Rest-Feature-Layer
