node-red-contrib-arc-modbus 0.1.9
a powerful modbus tool for node-red
npm install node-red-contrib-arc-modbus
README
node-red-node-arc-modbus
This is a modbus polling tool base on Modbus RTU protocol. The node were able to send modbus requests according to the established rule table. And collects responses to make the final result. It can be switched polling behavior by input msg.poll. It can send "write request" command by input msg.write. It can handle modbus exception code. The modbus function code 01 02 03 04 05 06 15 16 has been implementation.
arc modbus polling
1.Example
example
[{"id":"c1839961.6e41c8","type":"arc-modbus-polling","z":"e7ca081.068c0f8","timeouts":"1000","interval":"50","rules":[{"access":"RW_Regs","regs_addr":"0","regs_num":"10"},{"access":"RW_Regs","regs_addr":"10","regs_num":"150"},{"access":"RW_Bits","regs_addr":"0","regs_num":"50"}],"disable_polling":false,"name":"","x":690,"y":900,"wires":[["da916d29.d84b9"],["18eb5449.277f0c","b24d29f.d9fbcd8"],["332103d3.e913dc"]]},{"id":"da916d29.d84b9","type":"tcp request","z":"e7ca081.068c0f8","server":"127.0.0.1","port":"502","out":"sit","splitc":" ","name":"","x":580,"y":780,"wires":[["3ec5564f.e1c79a"]]},{"id":"3ec5564f.e1c79a","type":"change","z":"e7ca081.068c0f8","name":"payload -> response","rules":[{"t":"move","p":"payload","pt":"msg","to":"response","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":780,"wires":[["c1839961.6e41c8","7a33efc8.fa863"]]},{"id":"7a33efc8.fa863","type":"debug","z":"e7ca081.068c0f8","name":"response","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"response","x":1030,"y":780,"wires":[]},{"id":"18eb5449.277f0c","type":"debug","z":"e7ca081.068c0f8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":890,"y":900,"wires":[]},{"id":"b24d29f.d9fbcd8","type":"debug","z":"e7ca081.068c0f8","name":"result","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.result","x":870,"y":940,"wires":[]},{"id":"6adecef4.800db","type":"inject","z":"e7ca081.068c0f8","name":"write bits (FC15)","topic":"","payload":"{\"address\":20,\"data\":[false,true,true,true]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":230,"y":820,"wires":[["506aa932.aba248"]]},{"id":"faf8573b.97de28","type":"inject","z":"e7ca081.068c0f8","name":"write value (FC16)","topic":"","payload":"{\"address\":40,\"data\":[99,88,77,666]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":900,"wires":[["506aa932.aba248"]]},{"id":"229804ec.da124c","type":"inject","z":"e7ca081.068c0f8","name":"write value (FC06)","topic":"","payload":"{\"address\":30,\"data\":123}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":860,"wires":[["506aa932.aba248"]]},{"id":"506aa932.aba248","type":"change","z":"e7ca081.068c0f8","name":"payload -> write","rules":[{"t":"move","p":"payload","pt":"msg","to":"write","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":900,"wires":[["c1839961.6e41c8"]]},{"id":"96e684f0.cb0ed8","type":"inject","z":"e7ca081.068c0f8","name":"write bit (FC05)","topic":"","payload":"{\"address\":10,\"data\":false}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":230,"y":780,"wires":[["506aa932.aba248"]]},{"id":"332103d3.e913dc","type":"debug","z":"e7ca081.068c0f8","name":"exception msg","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":900,"y":980,"wires":[]},{"id":"1c6edf03.18e9f1","type":"inject","z":"e7ca081.068c0f8","name":"once","topic":"","payload":"once","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":1080,"wires":[["dbd3c9e3.d8f368"]]},{"id":"dbd3c9e3.d8f368","type":"change","z":"e7ca081.068c0f8","name":"","rules":[{"t":"set","p":"poll","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":1040,"wires":[["c1839961.6e41c8"]]},{"id":"5a924938.8a75e8","type":"inject","z":"e7ca081.068c0f8","name":"","topic":"","payload":"start","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":1120,"wires":[["dbd3c9e3.d8f368"]]},{"id":"dbd1d4b7.418cc8","type":"inject","z":"e7ca081.068c0f8","name":"","topic":"","payload":"stop","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":250,"y":1040,"wires":[["dbd3c9e3.d8f368"]]},{"id":"3c69506.230b3b","type":"comment","z":"e7ca081.068c0f8","name":"example of write","info":"","x":230,"y":740,"wires":[]},{"id":"53f259b3.c6c3d8","type":"comment","z":"e7ca081.068c0f8","name":"example of control polling behavior","info":"","x":160,"y":1000,"wires":[]}]
2. Node msg
2.1 Outputs
Output 1 (buffer) Request packets
  • payload The request of modbus packets.
Output 2 (JSON) Result
  • payload.result The infomation of modbus slave response result.
  • payload.rule The rule of this result.
  • payload.pkg Request and response of this result.
Output 3 (JSON) Exception
  • payload.result The infomation of exception (e.g. exception code).
  • payload.rule The rule of this exception.
  • payload.pkg Request and response of this exception.
2.2 Inputs
msg.response (buffer)
  • Packets response from the Modbus device.
msg.write (JSON)
  • This command can be used to trigger a write request. Please refer to the example region example of write.
msg.poll (string)
  • You can switch to continue or stop polling by string ("start", "stop", "once"). As long as msg contains this property, it node will trigger to poll once.
2.3 Parameters
para
Timeouts (millisecond)
  • The timeout for waiting receive response.
Interval (millisecond)
  • The waiting time before next request.
Polling Disable (checkbox)
  • This can set the initial polling behavior of the node. It also can be changed by msg.poll during process is running.
Rules (table)
2.4 References
arc modbus slave
It is still in chaos...
Version: 0.1.9
Updated 7 years, 1 month ago
17 in the last week
  • arc-modbus-polling
  • modbus
