node-red-contrib-apple-findme-reloaded 0.1.8
Node to request device and location data from Apple iCloud endpoints.
npm install node-red-contrib-apple-findme-reloaded
This is an alternate, much simpler, Apple FindMe node without bloat and API requests to third-party endpoints. FindMe-Reloaded only requests the official Apple API endpoints and does NOT request OpenStreetMap or other services, to prevent them track you. In addition, little transformation of data is done, to keep data clean and simple.
Apple currently provides no altitude information. FindMe-Reloaded won't ever try to fix that.
How to use
Add the FindMe-Reloaded request node to your flow, insert Apple account data and add an input (for triggering). After getting some output, do with it what you want.
example low
And yes: the node is violet, because its our beloved new iPhone color. I love it.
Caching
Minimum request time is 100 seconds to prevent you from getting banned. Your flow may request more often than that. In this case, you'll receive a cached payload. You can edit the throttling rate and set it much higher, for example when debugging your flow.
Example payload
    "isCached": false,
    "requestTime": "2022-09-17T18:48:08.803Z",
    "byModel": {
        "iPhone": [
                "id": "I42Hwv9ZJncHtTXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX",
                "name": "iPhone von 사장님",
                "modelName": "iPhone",
                "className": "iPhone",
                "deviceName": "iPhone 14 Pro Max",
                "rawName": "iPhone15,3",
                "uuid": "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX",
                "discoveryId": "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX",
                "battery": {
                    "level": 0.25999999046325684,
                    "status": "NotCharging",
                    "isCharging": false, // field provided by FindMe-Reloaded, makes life easier
                    "isDraining": true // field provided by FindMe-Reloaded, makes life easier
                "resources": {
                    "smallImage": "https://statici.icloud.com/fmipmobile/deviceImages-9.0/iPhone/iPhone15,3-1-17-0/online-infobox.png",
                    "mediumImage": "https://statici.icloud.com/fmipmobile/deviceImages-9.0/iPhone/iPhone15,3-1-17-0/online-infobox__2x.png",
                    "largeImage": "https://statici.icloud.com/fmipmobile/deviceImages-9.0/iPhone/iPhone15,3-1-17-0/online-infobox__3x.png"
                "hasLocation": true,
                "location": {
                    "latitude": 13.00000633701766,
                    "longitude": 37.000090778518228,
                    "horizontalAccuracy": 8.00001004653239,
                    "altitude": 0, // always 0, Apple isn't delivering values here
                    "verticalAccuracy": 0, // always 0, Apple isn't delivering values here
                    "positionType": "GPS",
                    "isOld": false,
                    "isInaccurate": false,
                    "lastUpdated": "2022-09-17T18:48:07.174Z"
        "MacBook Pro": [
        "Apple Watch": [
        "AirPods Pro": [
        "iPad": [
    "byName": {
        "iPhone von 사장님": {
            // reference to object above
        "MacBook Pro von 사장님": {
        "Apple Watch von 사장님": {
        "AirPods Pro von 사장님": {
        "iPad von 사장님": {
    "devices": {
        "I42Hwv9ZJncHtTXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX": {
        "8uzc8JI8GEWHEYlXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX": {
        "QkKnPAD4ajEXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX": {
        "Valiig13uowd78oF5iKPGAhYIxnHh4TXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX": {
        "uY4SLjrRXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX": {
Version: 0.1.8
Updated 3 years ago
Rating: 3.7 3
2 in the last week
  • apple-findme-account
  • apple-findme-request
  • apple
  • location
  • iphone
  • icloud
  • find-me
