node-red-contrib-api-call 0.3.0
A node for Node-Red to make API calls with flexible configuration
npm install node-red-contrib-api-call
A Node-RED node for making API calls with flexible configuration options
  • Make HTTP requests to external APIs
  • Support for various authentication methods (API keys, tokens)
  • Flexible configuration of API endpoints
  • Dynamic value support from message properties, flow, or global context
  • Easy integration with other Node-RED nodes
  1. Add the "API" node to your flow from the "api" category
  2. Configure the API endpoint and authentication details
  3. Connect it to other nodes as needed
  • API URL: The endpoint URL to call
  • Method: HTTP method (GET, POST, etc.)
  • Authorization: API key or token configuration
  • Property: Message property to store the response (default: msg.payload)
MIT
Version: 0.3.0
Updated 1 year, 6 months ago
4 in the last week
  • api call
  • api
  • call
  • http
  • rest
  • axios
