node-red-contrib-antenna-genius 2.2.0
Antenna Genius Control and Monitoring Nodes
npm install node-red-contrib-antenna-genius
Supports V3 and V4 of the Antenna Genius firmware.
Requires Node.js 18 or newer and Node-RED 3.1.0 or newer.
Node.js CI Node.js Package CodeQL njsscan sarif
image image
antenna-genius-band-labels
Returns the current band labels for radio A and radio B.
Properties
Server (antenna genius server): select antenna genius server to use.
Outputs
payload.bandLabelA (string): is the current band for Radio A as a string. For example 12m.
payload.bandLabelB (string): is the current band for Radio B as a string. For example 10m.
antenna-genius-antenna-status
Properties
Antenna Number (integer): Antenna number to get status for. Valid values are from 1 up to 32 (8 for one, 16 for two, 24 for three and 32 for four interconnected Antenna Geniuses).
Resend (seconds): while connected, re-send the current status this often even if nothing changed, so downstream nodes (for example dashboard buttons that remember the last topic) recover if they lose their state. Use 0 to disable. Leave blank for the default of 60.
Outputs
Port 1: Status for Radio A antenna.
payload.selected (boolean): this is the currently selected antenna for Radio A on the current band.
payload.enabled (boolean): this antenna can be selected for use by Radio A on the current band.
payload.name (string ): the name of this antenna.
payload.background (string): the suggested background color for the current antenna state.
enabled (boolean): same as payload.enabled.
topic (string): string that can be used to activate this antenna using the activate-antenna node.
Port 2: Status for Radio A antenna.
payload.selected (boolean): this is the currently selected antenna for Radio B on the current band.
payload.enabled (boolean): this antenna can be selected for use by Radio B on the current band.
Details
A typical workflow is to feed each output to a button and then map payload.name to the button's label, and payload.background to the button's background. Set the buttons payload to true and Topic to msg.topic when clicked and everything is setup to directly feed an activate-antenna node.
antenna-genius-activate-antenna
Set the antenna defined in topic as active.
Properties
Inputs
topic (string): Selection string for antenna. For example "1;5" for Radio A, antenna 5.
Details
See the antenna-status: node for more information. If a message without a topic is received, the current status is re-sent to all status nodes immediately.
antenna-genius-server
Antenna Genius shared connection configuration.
Host (string): Antenna Genius host name or IP address.
Port (integer): Antenna Genius port number.
Disabled Background (string): Background color to use for an antenna that is disabled.
Active Background (string): Background color to use for an antenna that is active (e.g. can be selected).
Selected Background (string): Background color to use for and antenna that is selected.
Version: 2.2.0
Updated 3 days ago
83 in the last week
  • antenna-genius-server
  • antenna-genius-band-labels
  • antenna-genius-antenna-status
  • antenna-genius-activate-antenna
