node-red-contrib-animate-gif 2.0.0
Node-red node for combining a set of buffers into an animated gif
npm install node-red-contrib-animate-gif
Node-red node for combining a set of buffers into an animated gif.
Getting Started
Install directly from your NodeRED's Setting Pallete
or
This assumes you have node-red already installed and working, if you need to install node-red see here
$ cd ~/.node-red
$ npm install node-red-contrib-animate-gif
This package provides a single node, animate-gif, which will be under the "functions" group in the pallete. The node exposes configuration settings for delay between frames, image dimensions, quality, and whether to repeat the loop or not. These settings can be set on the node settings, or on the incoming message.
  delay: 500,
  dimensionX: 100,
  dimensionY: 100,
  quality: 20,
  repeat: true,
  payload: [
      Buffer(...)
Version: 2.0.0
Updated 6 years, 1 month ago
Rating: 1.0 2
18 in the last week
  • animate-gif
  • jpg
  • gif
  • png
  • jpeg
