node-red-contrib-ams-decoder 1.1.5
Node for decoding norwegian ams energy meters
npm install node-red-contrib-ams-decoder
Node Red AMS Decoder
A Node-Red Node for decoding norwegian AMS energy meters.
Compability
The node`s are testet with Aidon and Kamstrup meters.
includes Beta Node for Kaifa meters.
Go to your Node-RED user folder (e.g. ~/.node-red) and run:
sudo npm i node-red-contrib-ams-decoder
The node expects a string from msg.payloadˁ containing the whole message from the AMS energy meter and ouputs the following:
msg.payload.obis_list_version
msg.payload.meter_ID
msg.payload.meter_model
msg.payload.act_pow_pos
msg.payload.act_pow_neg
msg.payload.react_pow_pos
msg.payload.react_pow_neg
msg.payload.curr_L1
msg.payload.curr_L2
msg.payload.curr_L3
msg.payload.volt_L1
msg.payload.volt_L2
msg.payload.volt_L3
msg.payload.date_time
msg.payload.act_energy_pos
msg.payload.act_energy_neg
msg.payload.react_energy_pos
msg.payload.react_energy_neg
Example
Fetch the message from the ams energy meter trough a USB-serial port by using the serialport node.
To get the serial port node you can install:
npm i node-red-node-serialport
These settings in the serialport node seems to work fine:
example1
from the ouput on the serial node use a function node to convert the binary buffer to String. The function node can contain something like:
msg.payload = msg.payload.toString('hex');
Then pass the output from the function node to the input of the ams_decoder to decode the ams message.
example2
Use the output as you like with the msg.payload properties as listet above
HAN interface info list info
The values are in raw format as described in the descriptions below:
Aidon:
https://www.nek.no/wp-content/uploads/2018/11/Aidon-HAN-Interface-Description-v10A-ID-34331.pdf
Kamstrup:
https://www.nek.no/wp-content/uploads/2018/10/Kamstrup-HAN-NVE-interface-description_rev_3_1.pdf
Kaifa:
https://www.nek.no/wp-content/uploads/2018/11/Kaifa-KFM_001.pdf
Version log
1.0.6: Includet beta node for Kaifa reader
1.1.0: changed output type from Class to Object, Included function to change input string to uppercase.
1.1.1: Minor bug fix in kamstrup node regarding time/date
1.1.3 Bug fix with Aidon node thath caused current to display wrong when producing energy to the grid.
Version: 1.1.5
Updated 6 years, 4 months ago
Rating: 5.0 3
11 in the last week
  • AMS Decoder Aidon
  • AMS Decoder Kamstrup
  • AMS Decoder Kaifa
