node-red-contrib-amqp-ssl 0.0.1
Node-RED AMQP input and output nodes
npm install node-red-contrib-amqp-ssl
node-red-contrib-amqp is a Node-RED package that connects directly to an AMQP server (e.g. RabbitMQ). It contains an input, an output and a configuration node to connect to AMQP exchanges or queues for Node-RED.
It uses the amqp-ts library for the AMQP connectivity.
Table of Contents
If you have installed Node-RED as a global node.js package (you use the command node-red anywhere to start it), you need to install node-red-contrib-amqp as a global package as well:
$[sudo] npm install -g node-red-contrib-amqp
If you have installed the .zip or cloned your own copy of Node-RED from github, you can install it as a normal npm package inside the Node-RED project directory:
<path/to/node-red>$ npm install node-red-contrib-amqp
Overview
The package contains the following Node-RED nodes:
input: amqp
Subscribes to an AMQP exchange or queue and reads messages from it. It outputs an object called msg containing the following fields:
  • msg.payload is a string or an object containing the content of the AMQP message.
  • msg.topic is a string containing the routing-key of the AMQP message.
  • msg.amqpMessage is an amqp-ts Message object containing the received message.sendto
If a topic is defined in the input node definition, that will be sent as msg.topic instead of the routing key.
In the settings you can only define the exchange type or queue and it's name. If you need to use an exchange or a queue with specific settings you can define the exchange or queue in the topology tab of the AMQP server configuration node. The input node will use the exchange or queue defined in the topology.
output: amqp
Delivers incoming the message payload to the specified exchange or queue. It expects an object called msg containing the following fields:
  • msg.payload: string or an object containing the content of the AMQP message to be sent.
  • msg.topic: string containing the routing-key of the AMQP message to be sent.
  • msg.options: object containing specific AMQP properties for the message to be sent, see the amqplib publish documentation for more information.
If a topic is defined in the output node definition, that will be sent as routing-key instead of the msg.topic. If the msg.payload field does not exist, the whole msg object will be sent.
In the settings you can only define the exchange type or queue and it's name. If you need to use an exchange or a queue with specific settings you can define the exchange or queue in the topology tab of the AMQP server configuration node. The output node will use the exchange or queue defined in the topology.
configuration: amqp-server
Defines the connection to the AMQP server. You can also define in more detail the exchanges and queues that are used in the input and output nodes and even define bindings between exchanges and queues in the topology tab.
topology tab
In the topology tab you can define the AMQP server exchange and queue topology (exchanges, queues and bindings). You define the topology in the JSON editor.
Topology configuration example:
    "exchanges": [
        {"name": "exchange1", "type": "direct", "options": {"durable": false}},
        {"name": "exchange2"}
    "queues": [
        {"name": "queue1", "options": {"messageTtl": 60000}},
        {"name": "queue2"}
    "bindings": [
        {"source": "exchange1", "queue": "queue1", "pattern": "debug", "args": {}},
        {"source": "exchange1", "exchange": "exchange2", "pattern": "error"},
        {"source": "exchange2", "queue": "queue2"}
Known issues
  • Entering invalid credentials (username/password) in the AMQP configuration node can cause node-red to malfunction
What's new
version 0.4.4
  • bugfix, topology editor not visible in amqp-server config node
version 0.4.3
  • bugfix, fixed routingkey not working in configuration/definition (thanks to exogenesick)
version 0.4.0
  • major refactor, made preparations for better testable code:
    • javascript source code has been translated to typescript
    • gulp build system added
version 0.3.0
  • connection to AMQP server now only established when amqp input and/or AMQP output nodes exist
  • major refactor and code cleanup
  • fixed errors in readme
version 0.2.0
  • fixed user credentials not working
  • improved readme
version 0.1.0
  • initial release
Roadmap
The roadmap section describes things that I want to add or change in the (hopefully near) future.
  • Add extra features
  • Make testable
  • Add localization
Version: 0.0.1
Updated 9 years, 4 months ago
3 in the last week
  • amqp in
  • amqp out
  • amqp-server
  • amqp
  • rabbitmq
  • amqp-ts
