node-red-contrib-amqp-credentials 0.0.1
Node-RED AMQP input and output nodes for docker
npm install node-red-contrib-amqp-credentials
node-red-contrib-amqp-credentials is a Node-RED package that connects directly to an AMQP server (e.g. RabbitMQ). It contains an input, an output and a configuration node to connect to AMQP exchanges or queues for Node-RED.
It uses the amqp-ts library for the AMQP connectivity.
Table of Contents
If you have installed Node-RED as a global node.js package (you use the command node-red anywhere to start it), you need to install node-red-contrib-amqp as a global package as well:
$[sudo] npm install -g node-red-contrib-amqp-credentials
If you have installed the .zip or cloned your own copy of Node-RED from github, you can install it as a normal npm package inside the Node-RED project directory:
<path/to/node-red>$ npm install node-red-contrib-amqp-credentials
Set Credentials
add credentials to settings.js
amqpConnect: { user: "usertoRabbitMQ", password: "userPasswordtoRabbitMQ" },
Overview
The package contains the following Node-RED nodes:
input: amqp
Subscribes to an AMQP exchange or queue and reads messages from it. It outputs an object called msg containing the following fields:
  • msg.payload is a string or an object containing the content of the AMQP message.
  • msg.topic is a string containing the routing-key of the AMQP message.
  • msg.amqpMessage is an amqp-ts Message object containing the received message.sendto
If a topic is defined in the input node definition, that will be sent as msg.topic instead of the routing key.
In the settings you can only define the exchange type or queue and it's name. If you need to use an exchange or a queue with specific settings you can define the exchange or queue in the topology tab of the AMQP server configuration node. The input node will use the exchange or queue defined in the topology.
output: amqp
Delivers incoming the message payload to the specified exchange or queue. It expects an object called msg containing the following fields:
  • msg.payload: string or an object containing the content of the AMQP message to be sent.
  • msg.topic: string containing the routing-key of the AMQP message to be sent.
  • msg.options: object containing specific AMQP properties for the message to be sent, see the amqplib publish documentation for more information.
If a topic is defined in the output node definition, that will be sent as routing-key instead of the msg.topic. If the msg.payload field does not exist, the whole msg object will be sent.
In the settings you can only define the exchange type or queue and it's name. If you need to use an exchange or a queue with specific settings you can define the exchange or queue in the topology tab of the AMQP server configuration node. The output node will use the exchange or queue defined in the topology.
configuration: amqp-server
Defines the connection to the AMQP server. You can also define in more detail the exchanges and queues that are used in the input and output nodes and even define bindings between exchanges and queues in the topology tab.
topology tab
In the topology tab you can define the AMQP server exchange and queue topology (exchanges, queues and bindings). You define the topology in the JSON editor.
Topology configuration example:
    "exchanges": [
        {"name": "exchange1", "type": "direct", "options": {"durable": false}},
        {"name": "exchange2"}
    "queues": [
        {"name": "queue1", "options": {"messageTtl": 60000}},
        {"name": "queue2"}
    "bindings": [
        {"source": "exchange1", "queue": "queue1", "pattern": "debug", "args": {}},
        {"source": "exchange1", "exchange": "exchange2", "pattern": "error"},
        {"source": "exchange2", "queue": "queue2"}
Known issues
  • Entering invalid credentials (username/password) in the AMQP configuration node can cause node-red to malfunction
  • Package library 'amqlib' is outdated, requiring breaking changes
  • Build libraries 'typescript' and 'gulp-typescript' are outdated, requiring breaking changes
  • BUG: When bringing up node-red at start, outgoing node sits in 'connecting'. Trivial change/deploy and it connects
  • POSSIBLE BUG: Observed along with the above bug, a message landing on the AMQP out node in the startup/non-connected state, that presumably should have failed to send, then throw an exception which would be caught in a catch node, is not throwing, and just failing silently
  • Very slow memory leak, unsure if this library, node-red in general, or outdated dependencies: In a test container with an AMQP-out node, sending out 30 messages/sec, with starting memory footprint of ~110 MB, slowly drifts up to ~150 MB, over a four day period.
Version: 0.0.1
1 in the last week
  • amqp in
  • amqp out
  • amqp-server
  • amqp
  • rabbitmq
  • amqp-credentials
