node-red-contrib-ampio-v2 1.3.0
Ampio node (device/v1 MQTT API), installable alongside node-red-contrib-ampio
npm install node-red-contrib-ampio-v2
Ampio Node-RED module (v2)
CI
Ampio add-on made to use Ampio Smart Home devices in Node-RED, using the device/v1 MQTT API.
Published as node-red-contrib-ampio-v2. It can be installed alongside the original node-red-contrib-ampio: all node types (Ampio v2 IN, Ampio v2 OUT, Ampio v2 LCD, Ampio v2 Events, Ampio v2 Audit, ampiov2config), the palette category (Ampio v2) and editor endpoints (/ampio-v2/...) have their own names, so existing v1 flows keep working.
Origin
This package is a fork of node-red-contrib-ampio by Ampio Sp. z o.o. (source: github.com/ampio-com/node-red-contrib-ampio), adapted to the new Ampio MQTT API. It keeps the original ISC license and copyright, see LICENSE, and is maintained separately from the original package.
Source of this fork: github.com/aii-gee/node-red-contrib-ampio-v2.
Leaf type definitions (ampioin/db/leafdefs.json) are generated from the Ampio Designer web application served by the Ampio server, see Leaf definitions.
Pre-requisites
You need Ampio Smart Home system, because this module is meant only to integrate it with another node-red plugins. You also need M-SERV-s with latest firmware, or Ampio Smart Home server installed in docker and connected through special serial-CAN adapter with Docker host device.
This node should be pre-installed on your M-SERV-s. In case of having software in Docker, use MENU -> Manage Palette -> Install and type ampio-v2. Another way is to use Terminal, and installing this add-on in your ~/.node-red directory.]
Using this add-on
After having this module installed, you will see helpful instructions in Help sections. Basically, after installing you will have 6 add-ons:
  • Ampio v2 IN, node meant to receive informations from modules, such like: states of inputs, outputs, flags, temperatures from sensors, states of analog inputs/outputs, and 8,16,32-bit measurements. Values will be delivered immediately, after they will change, they are not sent periodically.
  • Ampio v2 OUT, meant to control outputs and flagfs ion Ampio system. You can also change temperature controller desired temperatures.
  • Ampio v2 LCD, a complete tool to display text and shapes on LCD screen on MDOT touch panels.
  • Ampio v2 Events, to send and/or receive events from your CAN Network.
  • Ampio v2 Audit, reports every value change in the system as {value, moduleMac, moduleName, valueType, valueName, index, api}, with module and channel names from Ampio Designer.
  • Ampio v2 API, calls the HTTP API of the server (port 8060, user and password of the server config): controls mobile application objects (ex. setVirtualValue of virtual devices, setValue, turnOn), runs scenes, sends events and notifications, reads devices, groups, scenes and the logbook. Operations and their parameters come from the OpenAPI document of Ampio Designer.
Leaf definitions
ampioin/db/leafdefs.json lists every leaf type with its attributes (read/write access, value kind, range, unit, enum values, labels). It is generated from the Ampio Designer bundle served by the server:
curl -o /tmp/App.js http://<server>/assets/App-<hash>.js   # name of the main script from Designer page source
node tools/extract-designer-defs.js /tmp/App.js > ampioin/db/leafdefs.json
The script only evaluates plain object literals cut from the bundle, in an empty sandbox.
ampioin/db/openapi.json (operations of the Ampio v2 API node) is the "Ampio API" OpenAPI document embedded in the same bundle:
node tools/extract-designer-api.js /tmp/App.js > ampioin/db/openapi.json
then node tools/api-help.js writes the operations reference of the node help (ampioin/api.html) from it.
Development
npm ci
npm run lint     # ESLint
npm test         # unit tests (node:test), nodes run against an in-process MQTT broker
npm run check    # both
Tests live in test/: utils.test.js (topics, payloads, protobuf and description decoders, discovery), defs.test.js (definition files, editor HTML), extract.test.js (Designer extractor on a synthetic bundle), api.test.js (API node against a fake HTTP API) and nodes.test.js (IN/OUT/Audit/LCD/Events/config nodes with a stubbed Node-RED runtime).
GitHub Actions run lint, npm audit of runtime dependencies, a package contents check and the tests on Node 18, 20, 22 and 24 for every push and pull request.
Releases
Pushing a version tag stages the package on npm (.github/workflows/publish.yml), after the CI jobs pass and the tag matches package.json:
npm version patch   # or minor / major, creates commit and tag vX.Y.Z
git push --follow-tags
Publishing uses npm trusted publishing (OIDC), no npm token is stored in GitHub. Packages get npm provenance automatically. Setup:
  1. GitHub: repository settings → Environments → create npm (optionally with required reviewers).
  2. npmjs.com: package settings → Trusted publisher → GitHub Actions: organization aii-gee, repository node-red-contrib-ampio-v2, workflow publish.yml, environment npm.
The trusted publisher is configured on an existing package, so the very first version has to be published once by hand (npm publish), later versions are published by the workflow.
The workflow uses staged publishing (npm stage publish): a staged version is not public until a maintainer approves it with 2FA, on npmjs.com or with the CLI:
npm stage list node-red-contrib-ampio-v2
npm stage approve <stage-id>
npm stage publish is always allowed for a trusted publisher; direct npm publish would need the "Allow npm publish" option.
Changelog
Disclaimer: every version lower than 1.0.0 is considered as beta. I do all my best to make every release as stable as possible, but due to fast development of protocol, API changes may occur. 1.0.0 is planned after transition to /b/ MQTT broadcasts, which requires many changes.
1.3.x
1.3.0 - New node Ampio v2 API: calls the HTTP API of the server (M-SERV, port 8060, user and password of the server config) to control mobile application objects (setVirtualValue of virtual devices, setValue, turnOn, colours, blinds...), run scenes, send events and notifications, and read devices, groups, scenes, states and the logbook. Its 44 operations come from the "Ampio API" OpenAPI document embedded in Ampio Designer (ampioin/db/openapi.json, extracted by tools/extract-designer-api.js); they are listed by short name with the method first, ex. (GET) group_devices/{ID}. Parameters are set in the node or taken from msg.params, msg.<name> and msg.payload; JSON answers are parsed, control calls give "OK", and any other answer (ex. BAD REQUEST, DEVICE_DOES_NOT_EXISTS) is a node error. Object fields autocomplete application objects by name or id. Operation and parameter descriptions are in the node help, generated by tools/api-help.js.
1.2.x
1.2.1 - Same as 1.2.0, published again.
1.2.0 - Virtual devices of the mobile application (device type 256 added in Ampio Designer, ex. 11001001) are listed in IN marked application, with channel types and counts from the device configuration and names from the application objects bound to them (leaf 0_<mac>_<type>_<attribute>_<index>). They are not on CAN or device/v1: their values are set through the M-SERV API (/api/set/<object id>/setVirtualValue/<value>), so IN reads them from the object states ampio/fromDB/+/ob/<object id>/state, passing each change on once although the server publishes it for every application user. A channel needs an application object; the state is not retained, so the first value arrives on the first change. OUT does not list these devices.
1.1.x
1.1.1 - Repository moved to github.com/aii-gee/node-red-contrib-ampio-v2, npm package published from there. Same changes as 1.1.0, which was not published.
1.1.0 - Virtual devices: Satel (inputs, outputs, zones; MAC 0x3100000 | module) and Modbus slaves of M-CON-485 (167 - I32 generic, MAC 0x34xxxxx) are listed in IN/OUT/Audit with names from the parent module configuration (sections 36/37), marked virtual; other devices seen only on device/v1 are listed as virtual too. Device discovery asks get_devices first and then reads device/v1 and legacy retained states one after another: subscribing to all at once made the broker drop the get_devices answer and part of the retained states (devices without names, missing types). OUT checks device/v1 numeric values against the Designer range (modules wrap U8 300 to 44 and ignore text), converts numeric strings, and writes legacy 8 bit analog flags (afu8) as raw frame 7af9 <value> <index-1> (the /cmd topic does not set them). 16 bit analog flags (afi16) stay read-only.
1.0.x
1.0.0 - First release of node-red-contrib-ampio-v2. Package renamed to node-red-contrib-ampio-v2 with own node type names, so it does not collide with v1. Breaking: Ampio IN/OUT moved to the new MQTT API. State is read from device/v1/state/leaf/<MAC>/<type>/<attribute>/<index> and commands are sent to device/v1/set/leaf/<MAC>/<type>/<attribute>/<index>, with JSON payload {"v": value} (value can be an object, ex. RGBW {h,s,v}). Devices, types, channel counts, device names and channel descriptions are discovered with get_devices over rpc/v2/request/ampio-mqtt/<id> (same source as Ampio Designer); attributes come from retained states. IN/OUT editors list all readable/writable attributes of every type (generated from Ampio Designer definitions) with the expected value. OUT sends true/false as 1/0 and passes optional msg.time. Older CAN devices which are not available on device/v1 (M-SENS, M-REL-10s, M-DIM-2s, ...) are listed as legacy and used through the legacy ampio/from|to/<MAC>/... topics; legacy value types (flags, inputs, outputs, temperatures, sensors, zones, ...) are also offered for every device in a separate Legacy group, with channel names from device_api/to/list. Ampio v2 OUT can send raw CAN frames (type raw, hex payload) to ampio/to/<mac>/raw. New Ampio v2 Audit node reports every value change with module and channel names. Raw CAN commands, I/O descriptions and old value types were removed. Existing IN/OUT nodes must be reconfigured (device, type, attribute, index).
0.6.x
0.6.8 - support for CO2 in M-SENS
0.6.7 - support for new touch panels
0.6.6 - support for new devices
0.6.5 - add support for new devices
0.6.4 - "Legacy mode..." bug fix
0.6.3 - device list bug fix
0.6.2 - no changes
0.6.1 - no changes
0.6.0 - local unix-socket based connection option added
0.5.x
0.5.1 - Update devtypes.json 0.5.0 - add support for M-DOT-M18
0.4.x
0.4.5 - fixed LCD node.
0.4.4 - fixed an issue, when user opened node parameters, deviced list was being generated 3 times, which sometimes resulted in tripled outputs list. Removed faulty "update MQTT" warnings.
0.4.3 - fixed lack of support of linear flags in devices with protocol >= 22.
0.4.2 - bugfix - unknown device type was crashing device list. Now this bug is handled.
0.4.1 - bugfix, outputs were not visible for MIN-11p
0.4.0 - general update, modified backend to create only one, shared client for every MQTT broker, added config node, which gives possibility to store configurations of many brokers, updated list of device types. Manual configuration update is required after update - you will need to go add broker configuration and select it in ever Ampio Node.
0.3.x
0.3.0 - Added functionality of loading input/output descriptions from modules.Requires MQTT bridge in version 3.14 or later to support this functionality; corrected encoding in module names
0.2.x
0.2.5 - corrected big font bug
0.2.4 - corrected bug with flags
0.2.3 - corrected bug - outputs not working
0.2.2 - corrected the bug - MRT heating/cooling functions were not working, now it's OK; added IR codes sending from MSENS module; updated help files with latest functionalities
0.2.1 - added au8, au16, au32 values for MCON devices. Moved values descriptions to external database. Modified and updated help files. Created readme file and updated package.json to fit node-red requirements.
0.2.0 - general update, adding auto discovery for modules and auto-discovery for functions of modules
Version: 1.3.0
Updated 1 week, 3 days ago
533 in the last week
  • Ampio v2 IN
  • Ampio v2 OUT
  • Ampio v2 LCD
  • Ampio v2 Events
  • Ampio v2 Audit
  • Ampio v2 API
  • ampiov2config
  • ampio
  • Ampio Sp. z o.o.
