node-red-contrib-amazon-echo-aller 0.1.2
Alexa controlled Node-Red nodes supporting latest Amazon Echo devices
npm install node-red-contrib-amazon-echo-aller
NO Alexa Skills required.
NO cloud dependencies.
Install from your Node-RED Manage Palette
or
Install using npm
$ npm install node-red-contrib-amazon-echo-aller
How to use
  • Add Amazon Echo Hub node your flow
  • Add multiple Amazon Echo Device nodes linked to Amazon Echo Hub node Note: Use unique names for device nodes. Alexa will use the node name to manage your smart device
  • Ask "Alexa, discover devices" or start the discover procedure from the Alexa mobile app
Usage screenshot
  • Turning on/off
  • Dimming
  • Setting the light color
Supported devices
  • Amazon Echo 2nd generation
  • Amazon Echo Plus 2nd generation
  • Amazon Echo Dot 1st, 2nd and 3rd generations
Example Alexa commands
  • Alexa, turn on/off {device}
  • Alexa, switch on/off {device}
  • Alexa, set {device} to 50%
  • Alexa, turn my {device} light green
  • Alexa, set the {device} light to orange
  • Alexa, make the {device} warmer
  • Alexa, brighten {device} to 60 percent
  • Alexa, dim the {device} lights
Requirements
Amazon Echo Hub node is starting a service listening on port 80 which requires Node-Red process to be started with root user.
No additional settings are needed if Node-Red is started as Home Assistant add-on
Troubleshooting
Detailed troubleshooting instructions can be found on the Wiki
Bugs and feature requests
Please create an issue in GitHub
Version: 0.1.2
Updated 6 years, 7 months ago
Rating: 3.0 2
7 in the last week
  • amazon-echo-device
  • amazon-echo-hub
  • amazon
  • echo
  • alexa
  • phillips
  • hue
  • emulator
